Is the PING temparature sensitive?
I have my version of the garage assistant ( from completed projects ) happily assisting me everyday when I get home.· I've noticed lately that when the temperature is very cold outside ( naturally a bit warmer in the garage... but not by a vast·amount ) it seems to indicate· erratic or incorrect distance... later in the day... when it's warmer... all is normal.
There's nothing like a new idea and a warm soldering iron.
Your problem may simply be a matter of physics and weather. The speed of sound itself will vary based on any number of environmental factors. Extremes of temperature, humidity, atmospheric pressure and wind speed may all play a part, to one degree or another, in changing it.
So, somewhat regardless of whether the PING-)) is temperature sensitive itself, there may well be variations which are external to the unit.
Bruce Bates
One possible solution is to install a target at a known distance that can be rotated into and out of the field of view (using an RC servo, perhaps). This target can be used to calibrate the system periodically, so what you are measuring is the ratio of two distances: one known, and one unknown. The atmosphereic effects will then cancel out.
We do address temperature's effect on the speed of sound in air briefly in Chapter 2, Activity #5 of Smart Sensors and Applications, looking at percent error measurements. Temperature has a greater effect than either humidity or pollution in the speed of sound. But the percent error from room temperature to freezing is only about 4.5% I think.
-Stephanie
I guess I'm not really talking extremes here.
Is PING sensor temperature compensated?
howmuchsnow?
Tracy Allen
www.emesystems.com
Shawn Lowe
Maybe I should have waited to do that......
