Convert a Decimal value to Hex.
This is a clock project that displays the time on an lcd. There is a keypad for interaction. Basically a user can enter the current time from the keypad and set the clock. My problem is that the user will enter 59 as the minute but I need to convert that number to hex before I send it to the DS1302. So a 59 will become a 89. Without making a select/case for each number 0 thru 59 to convert, is there an easy way to convert minutes2 to hex and set it to minute? This is what i have so far:
Sub Get_Key
fformulaa
minutes = 0
loopdone = 0
SEROUT LCD, Baud, [noparse][[/noparse]LcdCls] ' Clear The LCD Display
PAUSE 5
SEROUT LCD, Baud, [noparse][[/noparse]"Enter minutes. 0 - 59 "]', LcdCR]
' loop through until the # key is pressed signaling that iput is done. Show only
' the last 2 keys pressed. so if 1 is entered 1 will show. 2 is pressed. 12 will show.
' 3 is pressed 23 will show, etc.
DO
IF keypress = 1 THEN 'key is pressed
IF minutes > 1999 THEN minutes = minutes //100 'drop first number for the next in line
GOSUB get_key
PAUSE 50
minutes2 = minutes // 100 'squish down to 2 digits
SEROUT LCD, Baud, [noparse][[/noparse]LCDline3]
PAUSE 50
SEROUT LCD, Baud, [noparse][[/noparse]"Minutes:", DEC minutes2]', LcdCR] 'shows the new numbers
IF LoopDone = 1 THEN EXIT 'if # key was pressed exit loop
ENDIF
LOOP
minutes = minutes2
Sub Get_Key
Get_Key:
SERIN TM,396,[noparse][[/noparse]KeyIn]
'DEBUG CRSRXY, 0, 0, HEX2 keyin, CR
SELECT KeyIn
CASE 0
'one was pressed
password = (password * 10) + 1
CASE 1
'2 was pressed
password = (password * 10) + 2
CASE 2
'3 was pressed
password = (password * 10) + 3
CASE 3
'A was pressed to clear the hour
password = 1
CASE 4
'4 was pressed
password = (password * 10) + 4
CASE 5
'5 was pressed
password = (password * 10) + 5
CASE 6
'6 was pressed
password = (password * 10) + 6
CASE 8
'7 was pressed
password = (password * 10) + 7
CASE 9
'8 was pressed
password = (password * 10) + 8
CASE 10
'9 was pressed
password = (password * 10) + 9
CASE 13
'0 was pressed
password = (password * 10) + 0
CASE 14
'# was pressed. Finish and goto next step
loopdone = 1
ENDSELECT
RETURN
fformulaa
http://forums.parallax.com/showthread.php?p=691369
You need to convert the keypad values, not into HEX, but into BCD. You'd use something like...
DSMinutes = ((minutes2 / 10)*16) + (minutes2 // 10)
