Power Supply: 12V in mutiple voltages out.
I'm working on getting everything connected and powered on my bot. Adding the Propeller added the requirement of 6-9V I also need 5V for various sensors. and I figure while I'm at it I want to add 3.3V. I'm no electronics expert so I would like some advice before I start into this.
From what I've read I could just power the proto board from the 12v supply, but no one really know the long term effect of this. so it's not advisable. especially with out heat sinks.
also the greater the difference in the input voltage and the out put voltage, the more heat will be generated. so the lower the voltage the larger the heat sink will need to be and the less efficient it will be.
I could cascade voltage regulators 9V, 5v, 3.3v. but with 1A regulators, by time I get down to the 3.3v I will have used part if not most of the 1A in heat. at least as I understand what is going on. I don't need much more than 1A, in addition to the Proto board.
Can any one give me suggestions on the best approach to this.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Post Edited (Dgswaner) : 11/27/2007 5:18:02 PM GMT
DGSwaner
- Stephen
DGSwaner
http://forums.parallax.com/showthread.php?p=685484
Best Regards,
Eric
DGSwaner
Post Edited (SailerMan) : 11/27/2007 8:13:33 PM GMT
like this one? beta.mouser.com/search/ProductDetail.aspx?R=18R154Cvirtualkey58010000virtualkey580-18R154C
I'm doing through hole.
DGSwaner
Post Edited (Dgswaner) : 11/27/2007 9:28:11 PM GMT
dkc3.digikey.com/PDF/T073/P1329.pdf
This is one example... Search for 150khz Inductors.
I am referring to the switching frequency of the regulator not the inductance of the Inductor
I would select one rated at more that 1 Amp.
Post Edited (SailerMan) : 11/28/2007 1:30:58 PM GMT
DGSwaner
It's become a pretty neat project for me, but If you just looking for a simple regulator go with the 7809.
What are you powering that needs 6v-9v ?
The 6-9v is for the Propeller Proto board. I need 5v for sensors and related hardware and 3.3 for a few things I would like to add later on.
I've looked on your other topic about measuring battery voltage, I'm trying to see if I can incorporate all of the ideas posted in that thread with your schematic.
DGSwaner
If you are using 9 volts on the proto board can't you just use a walwart? Or build your regualtor and bypass the one on the protoboard.
Are you going to to make a switching regulatoring board
If you do PLEASE·let me know
Thank You for your help in this matter
··Thanks for any·
Sam
DGSwaner
Mouser search results
(Passive Components>Inductors>Power Inductors, select "Stocked" in the part#/keyword box, then select:
Inductance=330uH
Termination Style=all but smd
Maximum DC Current=all current ratings from 1 amp up)
I will have to research what effect the frequency rating has, none of the ones I looked at really had one other than like "nominal @1kHz"
- Rick
DGSwaner
