SX memory page issue
I'm trying to implement a 256 element lookup table in assembly on an SX28.
The subroutine starts on the send page of memory $200. The main program that calls the routine is on the first page of memory. Everything works fine until the subroutine is called with a value in the 'w' register that has the routine jump to the table element stored at $300 or greater. I thought that the range of the second page is from $200-$3ff so I should not expect any problems with page references. Is there something inherently wrong with this approach. Attached is the code below.
reality is still analog
This is noted in the "SX Instruction Set" tables in the manual.
If you locate the "JMP PC+W" at a page boundary ($200, $400, etc), you can have at most 255 RETW #xx entries.
You might want to use the IREAD instruction instead.
Bean
www.iElectronicDesigns.com
Thanks for the help.
Place a subroutine code like
ReadTable
page Table
jmp w
into any code page, and place 256 RETIW n instructions into another page, (called "Table" here), and - voila - you may call ReadTable with w holding any value from 0 to 255, i.e. with 256 different values.
Greetings from Germany,
G
