Input voltage on the Propeller proto board
I'm in the very early stage of a 12V DC project that will be built around the Propeller Proto board. The proto board specs indicate the input voltage is 6 to 9 Volts DC which is regulated by the LM1086 regulators to 3.3 and 5 volts.
The data sheet for the LM1086 indicates the max input voltage is about 30 volts.
My questions are:
1. Is 9 volts the maximum voltage that can safely be·applied to the proto board's power input? If so, why?
2. Unless I'm totally missing something obvious, I should be able to·use a 12 V power supply.·Is this correct?
BT
My questions are:
BT
The explanation makes perfect sense.
BT
