The 7219 'scans' through the digits of the LED's it's displaying. You set the scan current with a single resistor, as I recall.
The difference is, a "constant current" LED driver puts out a lot of current -- up to 20 mA per lit LED. But a 'scanned' LED driver can light up an entire sign on 100 mA or so, spread around fast enough that your eye doesn't see 'flicker'.
Thank You!
