Tip: Bizarre compiler condition (with OWRESET)
Hello all,
I am sure this has been noticed before, but I could not find a note so just in case...
I recently created an SX/B program which compiled correctly but failed to run when "uploaded" to the device.
Basically the program was reading bytes from a 1-wire sensor. The OWRESET, pin, replyByte command would return nonsense in the replyByte.
Uploading a "stock" program to the device and all was well. So I knew it was a program fault. Checked every line of code 1 by 1 and all correct.
Now, changed the resonator to 50 mhz (from 4 mhz), and the compiler failed, warning me a memory location was being overwritten.
So that was it. I had exceeded memory - or at least was on the limit. (no surprise with the bloaty 1-wire stuff). The compiler did not complain with the 4mhz resonator DEVICE setting, so maybe this is an error ?
After removing a couple of VAR bytes and switching back to the 4mhz, problem solved.
SO- as a tip - if you are getting some bizarre results from your code which may seem otherwise perfect, try compiling with a 50mhz DEVICE setting! It may throw up an error to help you!
(Maybe there is some indicator of memory use in the IDE that could have also shown me this, but not aware of that feature)
That explains the 50mhz thing, although still a pity the compiler passed OK on 4mhz, when actually a memory conflict was waiting to happen. - Still, I know about it now!
As for the 1-wire subroutine thing, I have read this is a long-time "quibble" with the 1-wire stuff - 64-bit serial number code and management painful, single io pin code bearable but bloaty.
Actually following some of your earlier comments, I have been looking at i2c temp devices for later, just a balance of accuracy and price over the very low cost and +-0.5C "highly accurate" ds18b20's.
But for now, it occurs to me a future version of the SX IDE might allow passing of a PIN reference to a sub or function - which would enable 1wire code to be used simply in subroutines when wishing to communicate with multiple devices on separate pins. Just a thought...
There is no mechanism in the SX for passing a pin variable, e.g., RA.3. In PBASIC, many routines use a pin number, 0 to 15, and then those are massaged into a mask for the port that holds the target pin. You could update the 1-Wire routines I've attached and use the following subroutines for dealing with a given pin; in this case the valid numbers are 0..19 to handle all the I/Os on an SX28. Please keep in mind, however, that these routines take time so you may have to trim the 1-Wire timing to account for that, especially at low FREQ settings.
My point is not to be limited by what the compiler has built in, but to take advantage of its flexibility in creating custom routines. Keep in mind that SX/B has always been designed as a learning tool, and as such sometimes does things at a lower level than traditional compilers (which are certainly available at a variety of $ levels).
I believe the DS1621 is the I2C equivalent of the DS1620, and the DS1631 has even greater precision -- devices you might look into. In the end, I've used 1-Wire but am not a tremendous fan.
Post Edited (JonnyMac) : 11/25/2007 4:32:56 PM GMT
Can you post a version of your program that demonstrates the 4 MHz/50Mhz problem? I would like to see if this is a compiler issue or a SASM issue. I suspect SASM, but I won't know without a piece of code that demonstrates the problem.
PeterM
After a year it may now be irrelevant, but I post it anyhow in-case it helps.
Apologies to PeterM
Max.
So the same SX/B instructions require more program space when compiled at 50MHz compared to 4MHz.
The code at 4MHz uses 2013 of the 2047 instruction locations. Using 50MHz pushes it over the edge.
Bean.
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
The error message box that appears says "SASM Error", "Unable to assemble due to errors in source code"
Maybe it could be kinder and say "code exceeds instruction locations", as their are no errors in the source really?
Anyway, at least its a tip to note that if 50mhz code will not assemble and you cannot see why... try at a lower speed.
(There may be a smarter way to check this with the IDE, of which I am unaware. But as Bean has kindly mentioned the actual numbers of instruction locations involved, that might suggest it is possible to find that out, so I will have a look when I have some time.).
Max.
