microphone wireing (for dummies ;) )
For quite some time I've wanted to be able to hook up a microphone to my basic stamp projects and take readings from it one way or another, but all the threads I've read scare me away with all the technical terms. Are there any straight forward ways to take readings from a microphone? If anyone could also fill me in on the types of signals microphones produce, that would be helpful. I know I sound totally clueless, but this has always intrigued me and I'd like to pursue it. I know how to put together basic r/c circuits and have access to a/d converters, but thats about the extent of my knowledge. I just need to know what other parts i'd need, and where to begin with wiring. All help is appreciated!
Patrick
Patrick
Here is a link to the Propeller cookbook which shows a circuit with a microphone.
http://ucontroller.com/Propeller%20Protoboard%20Designs%20for%20the%20Beginner.pdf
It should be very easy to adapt it the BS2
Post Edited (Brian218) : 11/24/2007 10:48:57 AM GMT
Here's one circuit for sound detection. There are many others depending on what you want to do. Try searching the web for "sound detector".
www.seattlerobotics.org/encoder/200003/larryb.html
-Patrick
Basically, a microphone produces a small voltage or current in response to pressure on the diaphragm of the microphone.
An audio amplifier is simply an amplifier optimized for the audio frequency spectum (roughly 20Hz to 20KHz).
