Cool concept question...Laptop with extra power? — Parallax Forums
T&E EngineerT&E Engineer Posts: 1,396
edited 2007-11-26 08:08 in General Discussion
I was reading in an online magazine something about a contest that·a company like Intel is holding.
If you have a laptop and remove the power·cord and battery, how can you design in an alternate power source to keep the laptop running for 30 additional minutes kind of like what a UPS would do - but keep in all in the laptop idea.
I was thinking of either solar pannels built into the laptop case or possibly a super cap circuit.
What are your ideas? I thought this was an interesting question that I wanted to pass along for fun and discussion.
BTW: Happy Thanksgiving to all forum members!
    edited 2007-11-22 20:59
    T&E Engineer,
    The dimensions of the Solar Cells required for a stand alone Solar powered Laptop might prohibit a continuous Solar solution, but you could certainly design something that is rechargeable.
    Looking at my own Laptop... I have a 1.9Amp 19V power supply going into my Laptop.... 1.9Amp X 19V = 36 Watts ... For comparison, I also have a Solar Panel rated for 23 Watts that measures
    18 x 11 inches for an overall area of 198 square inches or roughly 9 square inches per Watt.
    Compared to my laptop dimensions of 16 x 11 inches for an overall area of 176 square inches I could produce about 19.5 Watts given the surface area of my laptop ... from a charging perspective,
    using Solar Cells, your charging ability would be almost cut in half compared to what you would have while you are "plugged in" with a power supply. This isn't necessarily a bad thing, the only thing
    I would be concerned with would be leaving my laptop sitting out in the sun.
    Beau Schwabe
    IC Layout Engineer
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2007-11-22 21:44
    You have some good points.·I just wanted to see what people might do to solve this as a fun exercise. Interesting concept all the same.
  • steve_bsteve_b Posts: 1,563
    edited 2007-11-22 23:31
    build a dynamometer that could plug in to a USB port and recharge the batter....not sure how happy the USB port would be with that!
    It could be small - handpowered....or it could be larger - pedal powered....
    <FONT>Steve
    What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
    Lee Travino after the second time being hit by lightning!
  • crgwbrcrgwbr Posts: 614
    edited 2007-11-24 00:24
    I have several flashlights that contain a small generator that is geared so when you squeeze a lever on the side, it generates power. Then, when you release the lever, a ratchet kicks in so that the generator can continue to spin. You could modify this concept, so that instead of powering LEDs, it goes through a v-reg and into the laptop. Then, if you're watching a movie or something passive like that on it, you could sit back and charge your laptop while getting a very gentle workout.
    "... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
    "If Python is executable pseudocode, then perl is executable line noise."
    "The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
    "My software never has bugs. It just develops random features."
    "Windows isn't a virus, viruses do something."
    "Programmers are tools for converting caffeine into code."
    "Enter any 11-digit prime number to continue."
    edited 2007-11-24 18:36
    Beau, what model laptop do you have?
    36W isn't that much, really. Even my humble 12" iBook(1.33GHz) has a 45W PSU, and I can't remember the last time I saw a HP PSU rated at less than 3.5A(usually at 18.5V)...
    My Psion MC400 runs about 20Hours on a 7.2V/1AH Ni-cad pack, but I doubt that you're using a computer that old...
    (1989)
    Anyway, a solar panel is not really going to do the trick, and if it's to be built INTO the machine itself, a hand-crank is probably not the way to go, either.
    Is the solution to be a 'multi-use' or single-shot solution?
    (single-shot assumes that you can do maintenance between uses, while multi-use assumes that it's instantly ready to use again)
    Don't visit my new website...
  • T&amp;E EngineerT&amp;E Engineer Posts: 1,396
    edited 2007-11-24 20:55
    I was able to find the electronic magazine I saw this contest in:
    Nov 2007 issue of Elektor (UK)
    http://depositfiles.com/en/files/2259791
    It's on page 40.
    It is also attached in a WORD document.
    edited 2007-11-26 02:56
    Gadgetman,
    Ohh Yeah.... Woops... I rechecked the Power Supply... try 7.9Amps at 19Volts rather than 1.9Amps at 19Volts ... So 150 Watts rather than 36 Watts.
    For some reason I could have sworn that it was 1.9Amps ... Anyway it's a 3.2GHz Gateway Laptop with 2 Gigs of Memory.
    Beau Schwabe
    IC Layout Engineer
    Of course, some of that capacity is for battery recharge and 'worst case' draws(several USB accessories) but still...
    We'd still have to assume at least 30W for a small/ultraportable or 45 - 60W for larger models.
    I'd still like to see the contest rules, not just the Elector article.
