Exturnal Memory size
samsn4
Is there something larger that what one can get through Digikey ? I'm using a bare setup 40pin dip, regulator, filter cap, crystal, and memory.
Daniel Mueth
WSIU-TV Master Control
"Just plug it in and let's see what happens"
Daniel Mueth
http://www.rayslogic.com/propeller/Programming/SD_Card/SD_Card.htm
If you want a bigger i2c eeprom, I think 64 kB is the biggest you'll find in DIP...· But, you can put several of these on the i2c bus...
Bean
www.iElectronicDesigns.com
