Matrix keypad code sample
![Peter Jakacki](https://forums.parallax.com/uploads/userpics/386/n4FB2N20UDSJF.png)
There has been some mention of how to interface matrix keypads. I am not aware of any code that could be used as a general-purpose object so I submit a version of one I have used that is written totally in Spin.
I do not consider myself proficient in Spin as I am constantly checking the manuals for usage etc so perhaps one of you Spin gurus (Mike?) can double-check the code that was adapted from a working 4X4 keypad.
*Peter*
*Peter*
{{ KEYPAD ENCODER - Peter Jakacki Starts up a cog that scans a keypad matrix and translates and buffers the codes. This code was originally written as a hardcoded 4X4 (tested) but was adapted for larger matrices (not tested) This is a simple but complete Spin implementation Keypad actions don't have to be fast but should be reliable so debounce periods are several ms The keypad matrix is made up of rows (horizontal) and columns. (vertical) All column lines are driven low while the row lines are inputs pulled high (10K). When a key is pressed one of the row lines will become low. The column lines are now scanned one by one to find out which column it belongs to. When the column is found the column index is combined with the row index to form a keycode. The keycode is translated in a user specified table and pushed into the keypad buffer. }} CON bufsz = 16 ' keypad buffer size (keep in multiples of 2) VAR long stack[noparse][[/noparse]32] long rows,cols,colpins,rowpins,akey,lastkey,keyrd,keywr,keycodes,ms1 byte keybuf[noparse][[/noparse]bufsz] ' Start the keypad scanner - column and row pins do not have to be adjacent ' If keypad code translation is required then set keycodeptr to address of ' translation table or else set to zero for no translation ' pub start(keyrows,keycols,firstcolpin,firstrowpin,keycodeptr) : okay | i rows := keyrows cols := keycols colpins := firstcolpin rowpins := firstrowpin keyrd := 0 keywr := 0 keycodes := keycodeptr ' remember pointer to user keycodes ms1 := clkfreq / 1000 - 4296 okay := cognew(scankeys,@stack) +1 ' run keypad in it's own cog ' Returns a non-zero value if there is a keypad code in the buffer ' pub getkey : keycode keycode := 0 if keywr <> keyrd keycode := keybuf[noparse][[/noparse]keyrd++&(bufsz-1)] return ' ******************* background methods run in their own cogs ******************** pri scankeys 'main scanning loop dira[noparse][[/noparse]rowpins..rowpins+rows-1]~ 'ensure row lines are inputs repeat outa[noparse][[/noparse]colpins..colpins+cols-1]~ 'drive all columns low (all active) dira[noparse][[/noparse]colpins..colpins+cols-1]~~ lastkey := 0 repeat until row 'wait until any key is pressed ms(5) 'oh hum, this is so boring ms(5) 'there was a signal, debounce if row 'double-check row again (noise?) keypressed 'seems solid, let's try to encode it pri keypressed | i outa[noparse][[/noparse]colpins..colpins+cols-1]~ 'columns are always active low repeat i from 0 to cols-1 'find out whch column is active dira[noparse][[/noparse]colpins..colpins+cols-1]~ 'all columns inactive except... dira[noparse][[/noparse]colpins+i]~~ 'only one column active ms(1) 'debounce period if row 'ignore false press (glitch) akey := i + (( >|row)-1 )*cols 'convert row and column if keycodes 'translate keycodes? akey := @keycodes.byte[noparse][[/noparse]akey] 'lookup new code (usually ASCII) if lastkey <> akey 'great! but is it a new key? lastkey := keybuf[noparse][[/noparse]keywr++&(bufsz-1)] := akey 'yes, let's buffer it release 'wait for button release return return pri release repeat until row == 0 'row lines are released repeat while row 'wait if still glitching (shouldn't) ms(5) 'debounce a further 5ms pri row return !ina[noparse][[/noparse]rowpins..rowpins+rows-1] & (rows*cols-1) pri ms(period) waitcnt(ms1*period + cnt)
I started up the buzz about the keypad, so far your code is the only one that i have gotten any response from. How did you have the
keypad wired to the prop? I'm using a 4x4 and the demo board.
attached is the schematic i have tried and some code
Daniel Mueth
WSIU-TV Master Control
"Just plug it in and let's see what happens"
Pins1-4 of the keypad go through a 1K to p0-3
Pins5-8 of the keypad go straight to p4-7 with 10K pull up's
Victory Dance:
Daniel Mueth
