Parallel stepper motor drivers
Hi
I have a Sherline stepper motor driver (controls 4 steppers) that runs my Sherline cnc mill.· I run·it with·EMC·software through the parallel port of a PC.· ·I would like to be able to·control this driver with a propeller chip but I don't have any specs on how the parallel port talks to the driver.· I assume this is pretty standard stuff, but I haven't been able to find anything on it.· Any ideas?
Normaly, you do have a DIR and a STEP signal for each motor. Thing remaining is finding out the pins.
DIR selects the direction.
STEP is a pulse for each step the stepper has to do. Watch out for the highest frequency possible, the controller won't do buffering.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Your Sherline EMC D25 printer connection will be like this,
http://www.sherline.com/8760pg.htm
The propeller needs to provide the step pulses at rates that allow for accelaration, max velocity and distance.
There have been a few forums on this and even a few objects.
Gavin
