how do i use an alternative font map? — Parallax Forums
aempireiaempirei Posts: 6
edited 2007-11-21 21:03 in Propeller 1
i was looking through the VGA-1280x1024 demo and driver and i cannot find what part of the assembly code points to the base address where the ROM font is stored ($8000) i want to use an alternative font map for the fonts (ideally i'd like to just replace the top font tiles 192-255)
  • RaymanRayman Posts: 16,460
    edited 2007-11-21 19:12
    I have a program to generate user characters and a demo app that uses them here:
    http://www.rayslogic.com/propeller/Programming/InterleavedCharacter.htm
    But, this is for the 1024x768 driver and you may have to tweak a few things for 1280x1024...
    The 1280x1024 driver is tile based, because of this the memory is viewed as blocks of 16 longs. Since each long is 4 bytes, each tile is 64 bytes long or $40 hex. $8000/$40 is $200, this is where the $200 comes from in the print method when i is computed for ASCII values $20 through $FF. To create your own subfont, decrease the case statement to $20..$BF and insert another case for $C0..$FF where the i value is constructed using the base pointer to your font. If you haven't already figured it out your font must be aligned on a 64 byte boundry (this means the 6 LSBs must be 0 for the start address of your font)
    Paul Baker
