car electronics question - jump starting
Hello All,
A question.· Why when jump starting a car with a dead battery from either a booster pack, or another vehicle, do the instructions always read:
1) Connect positive to positive
2)·Connect negative (booster/other car) to engine block of the dead vehicle - NOT the minus terminal of the battery
Seems odd as i've always done Neg-2-Neg, then Pos-2-Pos both jumpstarting and generally connecting batteries to stuff.
So the questions:
1) Why positive first?
2)·Why not neg to minus on the battery?
Only thing I can find on-line is when fitting a battery, that if you connect the positive first and accidentally ground the terminal - then without the neg attached nothing will happen.· Obv with the neg battery terminal connected it'd go bang!
Cheers,
James
So the questions:
Cheers,
James
- Rick
You avoid connecting the negative at the dead/weak battery in case of a spark.· Batteries produce hydrogen gas and a spark near the battery can cause an·explosion.· All car-type batteries·produce hydrogen gas and will have a vent somewhere, even if it's not obvious.· You make the final connection away from the battery so any spark that occurs is far enough away to not explode the hydrogen gas.· (Battery chargers are subject to the same problem, with the charger unplugged, connect it to the battery, then plug it in.· Reverse the procedure to disconnect.)
I hope this helped!
Interesting - thanks
James
