transmission wireless
Hi
·· I'm looking for a program which enables me to transmit an order by·the wireless transmitter from parallax··when the light is enough·(so using a light detection sensor). Someone could help me to·solve this problem ??
Thank you.·
Thank you.·
·The wireless transmission depends on which radio set you choose. Most simply take serial data in and then send it out. The Stamp programs typically use SERIN and SEROUT. See the Help files for some samples of serial communication.
·Depending on the radio you choose, the communication range can be from a few feet to several miles.
·Cheers,
Tom Sisk
http://www.siskconsult.com
