For Sale Again! WBA-TH1M Sensirion SHT11 Temperature/Humidity Sensor Module
WBA Consulting
Please see the post #49 for information on a new batch of modules................
Hello all! I am wrapping up a module that makes use of the Sensirion SHT11 Temp/Humidity Sensor. This 0.42"X1.0" module has a bypass cap, pullup resistor for the data line, pull down resistor for the clock line, and inline protection resistors for both the clock and data lines. The module design allows for use of the Sensirion SF1 filter cap (if the posts are removed) so that the sensor can be mounted outside and survive the elements. Connections are made via a 4 pin 0.100" header as well as solder pads for wire attachment. The PCB is professionally made, but I opted to omit the silkscreen due to space constraints. There is a label on the back side that denotes the pinout. It can be used exactly the same as Parallax's 20818 module.
My first revision was complete last week, but I needed to make some changes to increase the versatility. I plan to finish up the "spec sheet" in the next week or so and post more details on a website. I will also be testing the module with various lengths of Cat5 and "silver satin" phone cable to prove out the claims I have seen on the net of using it up to 100 meters. I am starting with ~140 units and my target price will be around $25.
With all that said, I am currently looking for some input:
1) If you were to buy this module, how would you use it?
2) Would you be more interested if the module was in some type of housing?
3) What microcontroller would you use for it? (BS2, SX, Prop, Tiny, Cypress PSoC, Atmel, MSP430, etc, etc)
4) Would you interface it with a wireless setup for remote sensing?
5) Would you want to buy the raw PCB if you already have a SHT11 sensor? (but only have wires soldered to it)
6) What other feedback can you give me based upon the paragraphs above?
7) If I offered a trade up for your Parallax module, would you consider that?
Any and all feedback is greatly appreciated.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Post Edited (WBA Consulting) : 6/10/2010 4:31:54 PM GMT
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
This a very nicely layout board
Look very Good
I would buy just the way that you have it in the photo
··Thanks for any·
Sam
- Rick
Andrew Williams
WBA Consulting
Raf
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Andrew Williams
WBA Consulting
1) Detailed description and schematic of your entire setup.
2) Code for the device of your choosing (SX, prop, BS, etc) .
3) Pictures of your setup.
4) Text file of a 24 hour period of data logging from the device. (at least 10 readings per hour)
5) Comments/feedback on the module's performance.
Of course I would be a little more detailed expectations in the auction, but you get the idea. I should be able to get these modules up on eBay by 12/9.
thanks!
Andrew Williams
WBA Consulting
I have the boards and a few will be built this week, but won't be on eBay til after Christmas. I did finish some testing and think I found what I was looking for. I attached one of my non-SF1 cap modules to the end of a 208 foot long piece of Cat5 cable (the last of a box I had) and the other end to a BS2 homework board. I placed it into a tree about 5 foot above the ground and used a piece of vinyl to make a rain deflector just in case. I setup a program to log to Stampplot for 3 days with readings every 20 seconds. The heater was turned on for two seconds every 5 minutes. It worked great for the entire 3 days. Even when it poured down one night and the wind blew off the deflector. Apparently water made it into the sensor; the humidity reading was at 100% for 5 hours until I blew into the sensor opening to force out the water. The temp readings were fairly accurate when the humidity was at 100%. I did not experience any anomalies in the data other than that. I think the key is to pair the data line with Gnd and the clock with Vdd in the Cat5:
Cat5 Sensor
Blue Vdd
Blue/Wht Clock
Green Gnd
Green/Wht Data
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
I checked wunderground during most of the tests I ran and my readings were very close to a PWS that is about 3 miles away. I learned a bit about proper enclosures to prevent the sensor from being adversely affected, but haven't made one that looks "professional".
Also, I only have basic logging code and testing code for the sensors. I would like to make a setup to monitor and log from 12 sensors that I will be installing in my house (3 BR, LR, Kitchen, garage, hallway@thermostat, 2 in the attic, front porch, back patio, and the roof) My ultimate goal would be to have all 12 sensors load to a webpage like Camalie Vineyards http://63.199.138.244/graphq.php
Andrew Williams
WBA Consulting
I'll load up a picture of my initial setup for reference later when I get to my camera. I'll gladly accept any feedback/criticism on the code's structure, cleanliness, etc. I am still not happy with the way I switch between the two modules, since the main section is just copied and hardcoded for the pin changes on each module. I would also like to switch this to my PDB with BS2P40 and use the 7seg LEDs, but I cannot get my BS2p40 to work right with pins above pin 8. that's another story....
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
I've been doing very well with sales on these, so I figure it's time to give back......
Also, I will eventually be selling the module without the sensor and headers. All caps and resistors·will be loaded and it will come with a 4 pin screw type terminal block (as seen on my proto board).
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 2/13/2009 5:18:06 PM GMT
Andrew Williams
WBA Consulting
www.aestheticacoustics.com/sht11_01.htm
Any feedback would be appreciated. My eBay auctions will now point to this page instead of containing all of the info.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 8/11/2009 5:27:25 PM GMT
Andrew Williams
WBA Consulting
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
Andrew Williams
WBA Consulting
I'll be posting a handful of modules on eBay over the next week that will include the SF1 filter cap. They will be started at $19.99, instead of the usual $14.99 for the module alone. I ordered 25 SF1 caps from Newark but I have only sold 15 of them; 12 for a shipment of SHT15 modules to Australia and 3 that are on their way to some caves in Italy (can't wait for those pics). There was a price break at 25 and I figured the extras would be a good selling point for my modules on eBay.
Andrew Williams
WBA Consulting
It is holding up well in agricultural areas. The radiation shield protects it from direct exposure to the elements. In the photo, the SF1 & SHT15 are in an encapsulation shell with the Rs and Cs, and the shell is filled with epoxy. It has a slow thermal time constant, but that is okay for the ag environment. In prototypes, I tried embedding the SF1 in a pool of conformal material without the shell, but the SF1 is made of a low surface energy plastic (polyethylene?) and nothing sticks to it well. The sensors worked okay, but I felt the shell would be a more secure option, despite the extra thermal mass. The SF1 is of course meant to be used that way, sticking up from inside an enclosure.
For other applications, I prefer the SHT75 on the narrow stock, and for protection I use the Goretex vent patches we talked about in another exchange.
Tracy Allen
www.emesystems.com
Thanks for the feedback, that's excellent. I have also tried sealing the SHT directly and have seen the attachment issues you mention. I have used Cyanoacrylate based glues to attach the SF1 cap first, then seal with an RTV. That has helped with caps coming loose. We have some sealant we are using at work that dries amazingly crystal clear and I may try sealing up one of the sensors in a mold with it. The stuff isn't cheap, so it would just be an experiment.
Where do you obtain your Goretex? I have not been able to find any up here in NorCal, but have been told there is a large fabric store in SF that has it.
thanks again
Andrew Williams
WBA Consulting
Now I'm using adhesive vents from Gore.. They have a disk of very permeable membrane in the center, surrounded by a donut of aggressive acrylic adhesive.
Tracy Allen
www.emesystems.com
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Post Edited (WBA Consulting) : 11/12/2009 1:37:12 AM GMT
www.gadgetgangster.com/find-a-project/56?projectnum=235
Andrew Williams
WBA Consulting
It's a pretty cool little sensor - the price is very reasonable, and there's plenty of sample code to help get started. I put up a note on it a Let's Make Robots, and Gareth pointed out a really cool Remote Temp sensor project he did, it's an interesting read.
Gadget Gangster - Share your Electronic Projects
