My question is: Who would be willing to coach me in the development of the project I spoke about below because I lack experience but am eager and work hard at it.
I think you will be able to get lots of help here on the forum. But, its much better if you can show us a schematic of what you need or even some of the code you've tried.
Your project is not too difficult; just break it down into sections and work on each one. For instance, get the LCD display hooked up and display the basic information. Then, you could get an a/d converter hooked up to measure and display the battery voltage. Get the sensor information into the Stamp ( either on/off or more analog signals) and do the programming so the logic gives you what you need.
Hi Tom,
I've been reading a lot these past nights and I am trying hard to break it down. I appreciate your comment and as things developp I will keep you posted.
I like your picture and am wondering, are you in heavy equipment...
Thanks a lot,
The machine is an automated delimber/processor. I designed the controller that takes over the hydraulics of the carrier and measures the log, then cuts it to length.
Interesting. We build service trucks for heavy machinery companies such as federal Equipment, Hewitt, Caterpillar and we just created a Powerbox, intelligent motor that starts upon demand of energy and stops when not in use.
Our present website is so-so...we are in the midst of setting one up.
Thank you Tom,
Cheers,
Tom Sisk
http://www.siskconsult.com
Thanks a lot,
You can see a few other projects on my website.
Cheers
Tom Sisk
Thank you Tom,
Regards
