simulate two variable frequency signals
Hey Community,
I am trying to simulate two variable frequency signals to be interpreted by a module. What I am looking for is basically a PWMPal, but frequency instead of PWM.
I need the signals to be constantly transmitting. Then change frequency when commanded to by a Basic Stamp.
Any one have any ideas?
A PWM signal of 5volts and a duty cycle of 50% will look like 2.5Volts on a regular RMS meter.... (is this a fair statement to make folks? I'm sure there's a formula I don't remember for this).
A duty cycle of 75% would give 3.75Volts..etc...
cache.national.com/ds/LM/LM2907.pdf is a link to a freq to voltage IC.
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
the Frequency of the RPM signal would be RPM/60, so a range of 13 Hz to 233 Hz
the frequency of the wheel speed (hall effect) would be less than one hz at the slow end and up to 23 hz at the the fastest.
One of my big questions has been weather this system I"m looking to fool reads it's sensors by measuring on time or frequency. The product is still on order, so I don't have it in hand yet to test. Looking at what the wheel speed signals would be if it measured frequency, I'm tinking that it would make more sense that the system looks at signal on time.
