Use of a Propeller chip to be a Address counter to a High-speed 32K x 8bit SRAM.
Newbee questions about the Propeller.
Address Inputs A0 to A14 for the SRAM 15 ns. I need to use 15 I/O ports for the 15 adresslines.
Propeller chip will more or less be a binary counter.
Must use Assembly since the speed must be more than 20Mhz· Write to Sram.· Read from Sram much slower.
Have follow DeSilva excellent AssemblyTutorial.· I can adress up to $ 1FF ( Dec 511 ) if i address more then a got a error Register/Constant
cannot exceed $ 1FF any tip or solution do i have to use more cogs ?
Thanks in advance
Lob
Thanks in advance
Lob
Immediate addressing only supports $000 to $1FF, after that you need to store numbers in a 'variable'
DAT
org 0
mov adr,myVar
add myVar,#1
myVar long $200
( Presumably you have an instruction similar to "mov adr,#$1FF" and you're trying to use "mov adr,#$200" ? )
Yes it is exactly what i do and got the error Register/Constant
Thanks again hippy
Lob
My intention is to generate all addresses between 0000 and 7fff with the Propeller i aware that i could use some Hc chips ie 4040 as adress counter for the Sram.
but if i am able to use the propeller chip i can save a some counter chips and logic chips and the same time i can controll the output from the Sram with the propeller.
The output will go to a Usb chip. Ftdi 245
Re speed i belive i can a least adress the Sram with 20 mhz to 30 Mhz with propeller.
Thanks again Ale
Lob
But to my opinion there is the need for at least 3 instructions per access, so a true "High Speed" SRAM (10...20ns) will be of no advantage... a 50 ns SRAM will be fine...
But you can generate a clock to drive the counters with the propeller to write to the SRAM (when you input data fast enough)... and later drive it slower to transfer the data, and have another in to clear the counters. You will need 2 74act393 (or abt or another fast enough), they are not difficult to work with, 8 bits of output per chip
OUTA x
OUTA x
OUTA x
where the output also strobes the counter - with some delay (of - say 25 ns).
It depends what you want to do with that data...
There was a nice idea of simulating DMA" in one thread the other day, I liked very much (and commented to)...
The propeller chip will not write to Sram an 8 bit A/D will sample and write to Sram output from Sram go to Usb controller Ftdi 245
the intention with the propeller is to be a address counter for Sram a clock for the A/D , propeller will also handle Write/Read , Output enable for Sram and
controll the data flow from Sram to Usb by TXE, Wr on Ftdi chip .
Presently it is no running on breadbord with 4040 adresscounter and some logic chips
With the propeller chip the construction will only be 4 chips A/D , Sram, propeller and Usb. Except analog input to the A/D
Final project Oscilloscope.
I am now struggling with the output speed from propeller for the adresscounter, any idea best way to get max output speed for the adresscounter
Thanks again Ale / deSilva
Lob
You want to get 60 MSPS, sort of, no ?, in 32 kb chunks and later send that via USB, so reading chunks of 256 or more bytes at once are desired.
CE and WE can be tied to ground (AFAIK) and you can change addresses and the memory will be writable after the addresses settle, some xx ns, depending on the speed. That would reduce the need to toggle lines.
To read, you can do it slower, and IF the ADC supports tri-state outputs (very important), you do not need any buffers between the ADC and the FTDI.
Go for the just one counter for lower addresses, and test how reliable direct write (without *CS, *WE toggling) works.
The prop cannot generate addresses that fast (15ns), because the outputs are or'ed together, so if you interleave 4 COGs for instance, when one output is high, there is no way to make it 0.... but now that I think of it... maybe the video generator can be used to "fake" a counter with 8 outputs... that leaves the slow addresses to be done by soft... yes yes that could definitely work !!! Try it, did you get how ?, investigate it, and later, tell me how it works
Gru
