Building a basic stamp tool for dad...
Hey Guys,
My dad has a problem I would like to solve using BASIC Stamps and accessories.
Story:
He has cattle on a farm that is about 7 miles from his house.· He has a brother that lives across the street and also farms.· His brother·probably drives·by the gate 3-4 times a day.· Dad also checks on them once a day.· He would have to enter the gate and drive across the pasture to check the water level.· It would be nice to monitor it from·the street or his·brother's house.· Last week his brother called Dad to let him know that the cattle were acting strange (and that they probably were not getting water).· Dad rushes out to check the water level in the tank and it is all gone.· The problem is there is no way for him to know when the water runs out.
How I would like to solve it:
Joe
Story:
- Use a BS2 at both boxes
- Use a PING to sense the water level
- Use a temp sensor to indicate if the water is frozen
- Use a 912MHz Transceiver to send level to 2nd box at the street (or brother's house if it will reach)
- Use a 912MHz Transceiver to receive water level and temp
- Use LEDs to display "green" or "red" to·indicate an unacceptable water level or if frozen
- No external power source at the location of the PING sensor.
- No external power source at the street for the 2nd "box"
- Is solar the best choice for a "turn on and forget" system?
- ...if so, should it charge a large battery or a capacitor?
- How much power will these components pull?
Joe
www.emesystems.com
He builds BasicStamp-based environmental monitoring systems, and he's active on these forums. There is a lot of info there that you can use to develop your ideas.
Also look at the "What's a Microcontroller" and "Applied Sensors" texts that you can download from the parallax website.
As for radio communications, take a look at something like the Xbee modules. They are designed for building sensor networks, and will give you a lot of flexibility.
I have a Bobot as well as the "What's a Microcontroller" package.· I do need to check out the Xbee stuff.
Joe
- Stephen
Device here.
|··············································· |_____|···· |··································· |________________________________________|
EDIT: I couldn't change the background color but I think yuo can read it now.
--DFaust
Post Edited (D Faust) : 11/20/2007 8:19:25 PM GMT
A float wouldn't work so well in the winter. And getting heaters would put a crunch on a power budget.
A ping might echo around in a metal tank.
A conductive strip running down the side of the tank might work. Also, a rod with water proofed temp sensors at different heights would work as well (am putting together one of these to find the 'inversion layer' in a frozen lake -- to know what level to put the bait at for ice-fishing!).
An IR range detector might work....unsure!
If the tank is visible from the road you might just put a flashing light on it.
Solar with a battery is good! Build a battery box with some insulation for winter....although you don't want it to heat up too much in the summer either!
You could put a receiver unit in the truck (if he's driving by all the time) or one in the house (range dependant) and that saves on those power sources.
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
--DFaust
# Use a 912MHz Transceiver to send level to 2nd box at the street (or brother's house if it will reach)
# Use a 912MHz Transceiver to receive water level and temp
I'm not sure if your saying you need 2 transceivers, one for each. but you only need one transmitter and one receiver. this should be cheaper than a tranciever on each end.
The Stamp can "sleep" for a specified time where it will go into a low power mode. where you know that the tank isn't going to instantly drain. I would have it check the level then sleep for 5 minutes or what ever time you feel best.
you should be able build the transmitting side of it, measure the power consumption over a giver period, then decide on the battery size? big enough for at least over night, plus cloudy days. then size a battery accordingly.
just brain storming here... lets say the tank went dry at 3:00 a.m. even if you dad did know it was empty would he fill it before morning? if not does it need to test the water levels at night? not running at night would save 8 +/- hours of usage, epically if no one would worry about it until morning, but then again those farmers do work early!
from what I understand your uncle lives across the street from the proposed receiver location. if so how about instead of using LED's for indicating an issue. provided they have internet, you could use a PINK. this way your dad or anyone for that matter could log on to it and see the exact level. could see the exact temperature, and force a water level check.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Once you have the hardware, you can fine tune the thresholds with software.
From Nuts & Volts:
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv27.pdf
This will not work when frozen.
SJW
Just use two wires at the minimum water level, when the water is over them, they will short and close the circuit, but when they are out of the water, the circuit will be open.
And seeing as you know the water level wont drop suddenly, I would only have it poll once every couple of hours.·Run the wires to a sealed underground box with your battery,·then run 2 wires and the antenna wire·out and up to a pole with a solar pannel and antenna. All your electronics are protected not only from cattle, but from the cold.
You could even run a ground wire and several sense wires, so you could have like 4 diffrent level sensors, which would also provide redundancy so one failed wire wouldnt trigger an alarm, or·worse not trigger a needed alarm.
and how to operate a stamp 1·from a supper cap. and a solar cell.
Read appliction No. 7 and 17 from the below Parallax document.
http://www.parallax.com/Portals/0/Downloads/appnt/stamps/bs1Appnotes.pdf
I hope this helps
SJW
If you have a water pump with a hose that can·reach from·a near by water source to the·cattles' drinking trough, you could also interface it with the controller so it would automatically fill the trough, when ever it falls below a certain level.
Any heavy duty lead acid batteries charged·with a solar charger should handle all your power requirements.
Just a few ideas
BT
http://scientificsonline.com/product.asp_Q_pn_E_3039813
Joe
http://www.cabelas.com/hprod-1/0027632.shtml
EPIC FAILURE -·When everyday run-of-the-mill failure just isn't good enough.
Even though it has multiple voltage outputs, it states it will charge 9v and AA batteries; no mention is made of others it could charge (rechargeable batteries aren't really my forte, so I'm not sure if it is practical to charge other batteries with it)
If you haven't already done so, do an internet search on battery charger circuit schematics and then choose a battery with recharging characteristics that the solar cell will support.
Here's a link for a fairly simple solar powered NiCad charger...I don't know if this would be practical to charge the cells while·they're in the controller circuit.
http://www.uoguelph.ca/~antoon/gadgets/solar1g.htm
Here a very nice solar panel Harbor Freight .com·· http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41144
This about 200 milamp output
If you have a Harbor Freight Store where you live they go on sale for $39.00
I have·two of the solar panels and work very well you need two panels for this two work
I have use it to charge my cell phone like you would in the car
Brian218
·http://www.uoguelph.ca/~antoon/gadgets/solar1g.htm
Thank You for your post and this web link
This will help me use·this·solar panel for a project that i have in mind
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 11/24/2007 1:29:45 PM GMT
Now I am getting ready to pull the trigger on the XBee RF Modules...· I am looking at the XBee Series 2 since I can·send·the data from an "End Device" to a "Router" and then to the "Coordinator".· As I understand it, this is how you send the data from a remote end device to the coordinator if the end device is "out of range" of the coordinator.· The router is the go between.· Do I understand this right?
See page 17 of this PDF...
http://www.maxstream.net/products/xbee-series-2/product-manual_XBee_Series2_OEM_RF-Modules_ZigBee.pdf
Lastly, is a BS2 required or will a BS1 work with these XBee modules?· I saw that the Parallax 900MHz units require the BS2.·
Joe
You'll also need a board through which you can change the firmware and setting on the XBee's for their functions and baud rates. DigiKey sells the USB interface boards, linked from my page:
http://www.selmaware.com/appbee
-Martin
SelmaWare Solutions - StampPlot GUI for controllers, XBee and Propeller Application Boards
Southern Illinois University Carbondale, Electronic Systems Technologies
Does·the board from Digikey serve the same function as what you get in the XBee development kit package?
Joe
-Martin
You might want to wait on buying the solar cells until after you've got everything built and working. This way you will know what you need for the power circuitry.
The·info in italics, at the bottom, is from Parallax's Basic stamp information page.
The BS2 consumes 3 mA when running, and only 50 micro amps in sleep mode. Assuming the pull-up/down resistors and supporting circuit don't consume much power, you might find the battery can go a long time w/o being recharged. You can probably buy a battery and charger for a cheaper price than the solar cells alone. The only drawback is you will have to recharge it every now and then; you can always add the solar calls later...
Best of luck with your project.
BT
Also, I have a few links for a surplus electronics vendor that carries ·discounted electronics components, batteries, chargers, and even solar cells)
I'm not sure if posting them would be considered spam or not.
I'll post it if the mods say it's ok. If not, send me a PM...
At 5 volts DC the BASIC Stamp 1 module consumes 1mA in running mode and 2µA in sleep mode, not including any circuitry on the I/O pins. The BS2-IC consumes 3mA in running mode and 50µA in sleep mode, not including any circuitry on the I/O pins. The BS2E-IC consumes 25mA in running mode and 200µA in sleep mode, not including any circuitry on the I/O pins. The BS2SX-IC consumes 60mA in running mode and 500µA in sleep mode, not including any circuitry on the I/O pins. The BS2P24-IC consumes 40mA in running mode and 350µA in sleep mode not including any circuitry on the I/O pins. The BS2P40-IC consumes 40mA in running mode and 350µA in sleep mode not including any circuitry on the I/O pins. The BS2PE-IC consumes 15mA in running mode and 150µA in sleep mode, not including any circuitry on the I/O pins. The BS2PX24-IC consumes 55mA in running mode and 450µA in sleep mode, not including any circuitry on the I/O pins.
Post Edited (Brian218) : 11/25/2007 1:02:47 PM GMT
Start by building a system that reports using lights. A flash per second means the system is functioning and water height and temperature are fine. A fast flash rate, or no flash indicates a problem with temperature or water level or power supply.
The temperature sensor only has to indicate freezing so it doesn't have to be calibrated for other temperatures. A capacitor discharge rate routine could be used to measure the resistance of a thermister. Add a pot so it can be recalibrated as needed.
Set a simple on/off water level gauge that measures "enough" or "getting to low".
Make the thing work with a battery. Test it for a week or two, especially in winter cold. Work out the bugs. Then add solar power. Then think about sensor upgrades.
Don't try to get fancy with a system that has to survive in a pasture or on grazing land. Make it simple, make it tough.
http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/CategoryID/49/List/0/Level/a/ProductID/86/Default.aspx?SortField=ProductName%2cProductName
Anyone know if this is waterproof?
Joe
