Hydra location of SD?
Oldbitcollector (Jeff)
Guys,
I'm working on a revision of BASIC as defined by Andre in "Potatohead's Plan" thread.
I'm curious if the typical Hydra owner is using an SD card yet, and where this card is being
hooked up? P16-P19?
OBC
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
hooked up? P16-P19?
OBC
I am laying out the SD card right now...
Andre'
DO- 16
Clk- 17
DI- 18
CS- 19
Andre'
Where's that thread?
Help to build the Propeller wiki - propeller.wikispaces.com
Prop Room Robotics - my web store for Roomba spare parts in the UK
simply plugs into the head intended for VGA. (Could we be seeing some standards arise? Nah... [noparse]:)[/noparse]
I have a working FemtoBASIC that does what Andre specified in message two of this thread..
http://forums.parallax.com/showthread.php?p=653180
(Potatohead's plan thread) But I sacrificed the EEPROM routines for more memory space.
I figured if there was an SD card in the works, it would see less use.
My code isn't the same, but the functionality is there...
I have a simple drawing program working with the NES controller. (Among other things)
I like the idea of an approachable language that a beginner can get started with.
(One that really does something...)
OBC
