[Help Needed]PropToll Idents Prop but Can't Download To It
Hello All,
I just got my propeller Starter Kit today and I've got it powered up and the drivers installed. When I run the propeller tool it identifies the Propeller on COM6 yet when I press F10(Compile to Ram?) it says it can't find the propeller! [noparse]:([/noparse] What am I doing wrong? I've restarted the propeller tool and the prop w/ a power cycle. Do I need to restart my computer?
Knowing my luck theres so very large warning infront of the book explaining these exact problem so I'm going back to reread!
Thanks in advance
[noparse][[/noparse]UPDATE] For some reason I can't seem to identify the propeller. When ever i click "Identify" the leds on the startkit go through a sequence(ie, running) and the blue and red leds flash. On one time I got "Propeller chip lost" error and other tries fail to find it at all.
HELP!
[noparse][[/noparse]UPDATE2] I got it to work but I still don't like the situation, inorder for me to get it to work I had to press f10 repeadly in quick succession(the first about 10 tries failed and then the last one succeeded)< Not a good sign?
Post Edited (DiablodeMorte) : 11/18/2007 3:04:38 AM GMT
Thanks in advance
HELP!
2) Make sure the Propeller is properly powered. There should be 6-9V available at the power connector with a current capacity of a couple of hundred mA.
The crystal doesn't have to work to use the Propeller Tool, but try wiggling it in its socket anyway.
3) Make sure your copy of Windows isn't trying to download updates. Sometimes that will interfere depending on how fast your machine is.
Now, I'm sure due to my abysmal relationship with Karma something else will fail, until then, thank you!
Paul Baker
