LEDs
Hello,
I use a lot of leds in my work. Usually·I run parallel strings of series groupings. I use 12 volts to power 3 leds in series and the appropriate resister depending on the led color and type of transistor (2n2222, uln2803, and tip120 depending on the needed current). This setup works pretty well for me, but I have been noticing a drop-off in current going to the leds. It seems that as I add more series groupings the leds start to draw less current. Last time I measured, it seemed like it was dropping about .6ma for each addition series grouping I added.
My questions are:
Is this supposed to happen and if so is there a way to measure it?
Here is a sample circuit...
Thanks for the help
My questions are:
Thanks for the help
And as Mike pointed out, how many LEDs is your transistor driving?· Try splitting up the up the LED strings between multiple drivers.
Post Edited (Desy2820) : 11/18/2007 3:11:08 AM GMT
