Driving a relay - do i need amplification?
I have a BS2 with Board of Education, and i need to drive eight miniature 5V-relays with it.
I have alrealy soldered the relays to a PCB, with diodes to protect from reverse voltage.
None of the relays will be active at the same time (only 1 will be active at a time).
The question here is; can i connect the relays directly to the pinouts on BOE, or do i need to amplify them with transistors?
Patrick.
Patrick.
Relays generate back EMF when the coil de-energizes. This is not good for the BASIC Stamp pins. Sometimes the coil current is near or above the current rating of the I/O pin. For this reason we often recommend using a transistor to drive the relay and use diodes on the coils. For multiple low current relays a single ULN2803 chip will provide both items in one package. Take care.
http://www.mcminone.com/product.asp?catalog_name=MCMProducts&product_id=26-539
can anyone recommend a relay that will pull-in?
If not, how do I configure a transistor, and can anyone recommedn one. I have a low voltage application that I want a simple relay to switch via BOE.
thanks in advance
