two steppers
I am trying to run 2 stepper motors using 8 I/Os I recall reading that the last 8 pins could be configured this way. I am imagining the first four I/Os to motor one and the higher four to motor two. Then I'm guessing I could make a sub rutine that could repeat for each moving mode, like; All ahead full, slow left, sharp left, spin left...
Could you show me 2 things?
1. a little code showing how to get to that mode where 8 LEDs can read values 0-255
2. how to make and call a sub rutine of slow and fast turns for instance
I'm thinking such a thing is already made, I'm just too new to find it
I think I have the BS2 it came with a book called What's a Microcontroller, but I didn't see this in the book.
Thanks very much
Bill
Thanks very much
Bill
4 wires usually bi polar
5 usually unipolar
You know that you will need transistors or somehting because a Stmap can't supply that much current. That WILL tie up your stamp too. (in code)
--DFaust
I think they are unipolar - all voltages in one direction
Yes, I have got 8 Darlington pair type Transisters to get the power requirements to the motors.
I'm so ready to get movement, I want try the byte 0-255 method with GOTO or GOSUB speed and turning schemes.
But, what's the real way, I'm very new to this, And I'm sure there are less taxing methods for these tasks. I cetainly haven't considered the sensors yet, just the go... my instant gradification plan is to just preprogram a rutine into it like; go straight 30", spin left 3 times, go left a little right a little roll in a serpatine (sine wave) kinda way, spinright a little, stop. Just so I can assure myself it will move
I have not done this but I would think of somehting like:
Dirs = $F
outs = %10000000
outs = %01000000
outs = %00100000
--DFaust
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
