Full datasheet now released
It's official, the Propeller is rated for military temperatures.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.0.pdf
Paul Baker
Paul Baker
"... conditions in excess of those given in the remainder of Section 7.0."
That "7.0" should be 8.0 I guess.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
He can only do what he can do... and if he did any more he'd be in trouble.
Rich
Paul Baker
Paul Baker
Wonder how many g's it can take...
I am become death, destroyer of worlds.
Power tends to corrupt, and absolute power corrupts absolutely. Great men are almost always bad men.
Graphs 9.2 and 9.3 have titles with different font sizes.
Very nice work
darco
www.deepdarc.com/
http://www.darpa.mil/sto/solicitations/DESERT/hstssbrief.pdf
I'm hoping I can save the data to a micro-SD card right before it hits the catcher...
The attached diagram from the Datasheet shows that Spin needs 2 times the current of Assembly.
I think the Spin Interpreter in the Cog is also just an Assembly code, so the higher current can only come from the constant Hub access, or from the case that other instructions then a jmp needs more current.
If low current consumptiom is an issue, it's important to know what the exact reason is.
Andy
Evidently both HUB accesses and SRAM/ROM accesses are quite expensive current-wise. We *still* do not know if the SPIN interpreter is fully loaded or there are portions still remaining in the ROM.
The Navy's wanted an Intra-theater/Intercontinental gun system for a while now.
I expect they'll get it here before never.
Yours, Tom Perkins
For the record, link to other data sheet threads:
http://forums.parallax.com/showthread.php?p=642521
http://forums.parallax.com/showthread.php?p=660907
I guess you must have made some kind of fixture to test several propellers at once. Can you say anything about how that testing is set up?
How about tempcos and spreads for RCslow and RCfast?
@Rayman--this isn't high Gs, but at high pressure of >600 atmospheres at 6500 meters of water it was the resonator that became the weak link. IThat might be a problem at high Gs too, unless you can fall back on RCfast.
Tracy Allen
www.emesystems.com
Ale, that was the working title for the in-house revisions, I can't find where in the published document where it still retains the working title.
Paul Baker
What kind of magnetic environment is there around the projectile during launch? Will the prop and eeprom be able to handle the induced currents (if there are any?)
