IR repeater
My brother and I share the direct tv through a splitter. The box is in my room tho so he cant change the channel to well from his room, can I make a repeater for IR to put in his room and and a transmitter in my room aimed at the box. That way he can change the channel from his room.
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
--DFaust
If your not opposed to running wire or are not using coax you can go this route. You'll need 1 - CB12 connecting block $15, 1 - 291-10 IR Receiver $45, 1 - IR emitter $4.50 - $15.00 (buy the house brand they are all the same), and a 12 volt power supply $12. You may also need an extension wire for the receiver or emitter, item 8186 at smarthome $9.
Post Edited (jmassoni) : 11/17/2007 3:05:47 PM GMT
