LTC 1298 ADC - outputs are unstable
I built a daughter board for a 1298 ADC, and all the hardware checks out. I have typed in the sample demo code for the chip, and it is interfaced to my BS2e on board my "FauxBoe". I can get steady readings with a voltage divider (10K pot) as long as I don't touch the pot. The Sharp sensors (GP2Y) I have on board are showing very jittery unstable outputs. Does anyone have a previous experience like this? Is there an improvement to the coding that can be made? Perhaps a different capacitor? My code does include an output to an LCD, i have tried it with debug only and it had no effect. Here is my code:
' ADC_Demo_FauxBoe.bse
' This program demonstrates the LTC1298 by alternately sampling the two
' input channels and presenting the results on the PC screen using Debug.
' {$STAMP BS2e}
' {$PBASIC 2.5}
' {$PORT COM1}
CS CON 10 'chip select; 0 = active, port 10
CLK CON 11 'clock to ADC; out on rising, in on falling edge, port 11
DIO_n CON 12 'data I/O pin number, port 12
config VAR Nib 'confifuration bits for ADC
AD VAR Word 'variable to hold AD result
startB VAR config.BIT0 'start bit for comm with ADC
sglDif VAR config.BIT1 'single-ended or differential mode
oddsign VAR config.BIT2 'channel selection
msbf VAR config.BIT3 'output 0's after data transfer complete
N9600 CON $4054 'baudemode 9600 bps inverted.
I CON 254 'instruction prefix value.
CLR CON 1 'LCD clear screen instruction.
L1_C2 CON 133
L2_C2 CON 197
SEROUT 8, N9600, [noparse][[/noparse]I, CLR] 'clear LCD screen
PAUSE 2000
SEROUT 8, N9600, [noparse][[/noparse]"Chan "] 'header print
HIGH CS ' Deactivate ADC to begin.
HIGH DIO_n ' Set data pin for first start bit.
again: ' Main loop.
FOR oddSign = 0 TO 1 ' Toggle between input channels.
GOSUB convert ' Get data from ADC.
DEBUG "channel ",DEC oddSign, ": ", DEC AD, CR ' Display data.
IF (oddsign = 0) THEN
SEROUT 8, N9600, [noparse][[/noparse]I, L1_C2, DEC oddsign, ": ", DEC AD] 'display data on LCD
ELSEIF (oddsign = 1) THEN
SEROUT 8, N9600, [noparse][[/noparse]I, L2_C2, DEC oddsign, ": ", DEC AD] 'display data on LCD
ENDIF
PAUSE 20 ' Wait a half second.
NEXT ' Change channels.
GOTO again ' Endless loop.
convert:
config = config | %1011 'set all bits except oddsign
LOW CS 'activate the ADC
SHIFTOUT DIO_n, CLK, LSBFIRST, [noparse][[/noparse]config\4] 'send config bits
SHIFTIN DIO_n, CLK, MSBFIRST, [noparse][[/noparse]AD\12] 'get data bits
HIGH CS 'deactivate the ADC
RETURN 'return to program
Thanks.
Brian
"I know just enough about electronics to be a
danger to myself and others."
' {$STAMP BS2e}
' {$PBASIC 2.5}
' {$PORT COM1}
L1_C2 CON 133
L2_C2 CON 197
PAUSE 2000
again: ' Main loop.
ENDIF
convert:
Thanks.
Brian
- Stephen
The schematic is the same as the one on the first page of the LTC1298 manual I got online at Parallax.
Brian
