Serial Communication using Labview
Can any one help me solve a serial communication problem using labview.
the problem is that, when I start my labview program, which is supposed to do a simple send and reveive operation using visa instance, the basic stamp (BS2) is reset continiously
I tried using a hyper Terminal for testing. it turned out that the basic stamp does not reset, but i had to send my character twise before a SERIN with wait detects it.
here is a listing of the basic stamp code below. I also Attached my labview program
thank you for your help
YB
YB
' {$STAMP BS2}
' {$PBASIC 2.5}
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
T9600 CON 84
T19K2 CON 32
#CASE BS2SX, BS2P
T2400 CON 1021
T9600 CON 240
T19K2 CON 110
#ENDSELECT
BaudR CON T9600
SerData VAR Byte
LOOP1:
LOW 10
SERIN 16, BaudR, [noparse][[/noparse]WAIT("CMD"),DEC SerData]
DEBUG CR, "you entered CMD: ", DEC SerData,CR
GOTO LOOP1
You need more than just tx/rx/gnd. There's another line (which name escapes me..ATN I think) that stops the stamp from shutting down.
Check the helpfile.
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
I'm using a usb version of the stamp education board. and I'm not aware if the usb device uses the attention line or not.
will have pass to someone else!
good luck!
<FONT>Steve
