Help with Counting frequency of tones
I have been struggling through the Counter Modules and Circuit Applications section
of the propeller education kit lab series (most of it way beyond my skill level).
I have been able to assemble a counter
program (attached as COUNTER1) Which counts the cycles of tones generated by
the propeller. the tones are generated in a separate COG and are measured on an
asynch basis. I take enough snippets of the tone to get a consistent number
for each frequency.
I thought I would take this a step further and generate tones external from the
propeller and measure them using a smaller propeller program (attached as COUNTER2).
I used a BS2 and the freqout command, to generate the tones. I used the same
frequencies and intervals, but got very different unusable
results. I don't have a scope, so I could only verify the tones by listening to them.
They sound okay, but the measurements are not. I made a direct connection from the PIN on
the BS2 through a 1K resistor to the Propeller pin.
I don't know if I have created a bad program which will only work with propeller generated
tones, or I have to build an interface from the stamp2 to the propeller.
Any help or guidance would be appreciated. Here are some examples of the results I am
getting with both of the programs. Please excuse the length of this question, but I wasnt
sure how else to ask it.
Propeller measuremet of 1K, 2K, and 3K Propeller generated tones
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 1010
Frequency = 1010
Frequency = 1020
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 2020
Frequency = 2020
Frequency = 2020
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 2240
Frequency = 3030
Frequency = 3030
Frequency = 2720
Frequency = 0
Frequency = 0
Frequency = 0
Propeller measurement of 1K, 2K, and 3K Freqout tones from STAMP
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 48640
Frequency = 48690
Frequency = 25850
Frequency = 0
Frequency = 0
Frequency = 47350
Frequency = 47750
Frequency = 47720
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 47690
Frequency = 47710
Frequency = 47740
Frequency = 0
Frequency = 0
Frequency = 13880
Thanks in advance for reading this and for any help you can provide.
Larry
for each frequency.
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 1010
Frequency = 1010
Frequency = 1020
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 2020
Frequency = 2020
Frequency = 2020
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 2240
Frequency = 3030
Frequency = 3030
Frequency = 2720
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 48640
Frequency = 48690
Frequency = 25850
Frequency = 0
Frequency = 0
Frequency = 47350
Frequency = 47750
Frequency = 47720
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 47690
Frequency = 47710
Frequency = 47740
Frequency = 0
Frequency = 0
Frequency = 13880
Larry
to create DTMF tones and it worked okay.· ·I will take your suggestion and try the low pass filter. I will
also find another source to generate the tones as a further benchmark for testing..
Larry
A substantial improvement of accuracy can be achieved when you set PHSA to zero just before the WAITCNT and read it immediately after the WAITCNT.
Subtracting 2300 is not a good idea for many reasons...
WAITCNT should take around 800 ticks extra only (ca. 10 µs @80 MHz)
It certainly improved the results (see below). I built a trial
and error filter using devices I had on hand. I still think working with
analog signal levels and frequencies is close to witchcraft, but I can't argue with
success. The RC filter component combination
that produced the best results were an a 1K ohm
resistor with .1MFD capacitor. I also changed the program to include
the suggestions DeSilva made. I also increased the reps by reducing the
waitcnt. (revised program attached)
Frequency = 21020
Frequency = 21420
Frequency = 21690
Frequency = 21130
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 22200
Frequency = 33530
Frequency = 32910
Frequency = 32470
Frequency = 27870
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 143470
Frequency = 146090
Frequency = 142430
Frequency = 144220
Frequency = 6450
Frequency = 0
Frequency = 0
Frequency = 0
Frequency = 0
Thank you both for your time and help.
Larry
