I swear my head is going to explode
Hello again. Newbie here.
In my previous post I explained that I am teaching electronics to myself, and I need some help again.
I want to turn on a DC motor.· Moreover, I want to be able to turn it on with the BS to run in either direction.
So, I purchased two Crydom DM0063 SSR's, and they both test out perfectly.· When I send a high singnal to the coil, I get zero resistance in load circuit, and when it is low, I get close to infiniate resistance (I know, there's no such thing as infinate, but you know what I mean).
So they work for DC current- sweet.
Now comes the hard part for me- it's probly super simple for you all.· I wired it up and the motor immediatly spun in one direction only.· I fired up the Fluke, and it is reading either 11 vDC or 12VDC depending on which relay is on- but no negative.· The way I had it wired is below:
After review, obviously this won't work- and it explains why I was getting positive voltage regardless on the fluke (I put the fluke betweeen the motor and the relays.· Obviously you can not·connect the motor directly to the battery and expect the relays to change polarity.
So I'm trying to draw the circuit out on a piece of paper, and I'm completely lost!· I just can't wrap my brain around this.· No matter how I draw it, I end up with a short circuit.· So obviously some diodes will have to be used, but even then I'm not sure how to do it.· Can anyone point to a schematic that can help me out here?· I'm going to keep working on it and hopefully will figure this out, but it would be nice to hear from some of you.
Thanks.
Thanks.
Told you I was new... [noparse]:([/noparse]
To turn a motor on and off, almost any kind of switch will do like your SSR or a power transistor or a simple relay.
To be able to reverse a motor too, you need to use a DPDT relay (and something to turn the power on and off) or
an H-bridge.
Now for the DPDT relay. They sell this at the local Radio Shack-
http://www.radioshack.com/product/index.jsp?productId=2049720&cp=&sr=1&origkw=dpdt+relay&kw=dpdt+relay&parentPage=search
Will this work? It says it has a 12VDC coil, but the BS only puts out 5. They guy at Radio Shack says it will, but he's just a kid. If not, what will? What do I need to look for?
You need a relay with a 5V coil or you need a source of 12V and a switching transistor to allow the Stamp to turn on the relay without being damaged by the excess voltage and current. The Stamp Manual, Stamps in Class tutorial and the StampWorks tutorial all give examples of using a switching transistor to control a relay or small motor. You could even use your SSR to control the 12V relay (running off of 12V).
Added the blue text
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Post Edited (Dgswaner) : 11/13/2007 10:58:18 PM GMT
Paul Baker
