SD card boot menu
Attached is a boot menu that will display all the *.BIN files you have on an SD card connected to pins
· spiDO· = 16
· spiClk = 17····
· spiDI· = 18
· spiCS· = 19
you can use the a·nes gamepad·or keyboard to scroll up and down and press select on the nes gamepad or enter on the keyboard to run the selected program
· spiDO· = 16
· spiClk = 17····
· spiDI· = 18
· spiCS· = 19
My only real comment is that on the NES pad, "Select" is a little non-intuitive as the load button. I'd possibly set it to say all of "A", "Start", and "Select" all work for loading.
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
Here is the code at your request, it uses Tomas Rokicki SD card driver, Doug Dingus text display driver
PS I would like to make it combatable with the prodo board aslo but I don't have one to test the changes with
Oldbitcollector
Here's the protoboard version.
I remarked the NES_Reader since most protoboards don't have that.
I've also made some other minor adjustments to the variables and speed of course.
OBC
