Spin RAM Wav Player (i.e., not from SD card but embedded data) — Parallax Forums
RaymanRayman Posts: 16,460
edited 2007-11-10 17:45 in Propeller 1
Here's another version that can play·mono, 8-bit, 8000 or 16000 samples/second PCM WAV file data...
You don't need an SD card for very short clips, as with this example.· The wave file is just included in the program data...
More info here:
http://www.rayslogic.com/propeller/Programming/dac/dac.htm
This might be useful for adding sound effects to small programs with lots of room left over...
If you have an SD card though, you probably should use the 16-bit version for better quality.
