DOSonChip Problem
I'm trying to get my DOSonChip working.
I'm using the info in this thread, but I'm having no luck.
http://forums.parallax.com/showthread.php?p=616115
I'm trying to use the VGA_Text object
This code fragment is using the TV, there is· outa[noparse][[/noparse]16] := 1 &· outa[noparse][[/noparse]17] := 1
How would I convert this to VGA ? I know I've got to use ... term.start(16) but... is that all ?
The screen goes blank like this
· dira[noparse][[/noparse]5] := 1
· outa[noparse][[/noparse]5] := 1
· dira[noparse][[/noparse]16..23] := $FF····················
· 'start the tv terminal
· term.start(16)
· term.str(string("Press Enter twice to begin.",13))
· 'start the keyboard
· kb.start(26, 27)
· ' start the serial cog
· doc.start(7, 6, %00, 9600)
· repeat
··· c := doc.rxcheck
··· if c <> -1
····· term.out(c)
····· outa[noparse][[/noparse]16] := 1
··· c := kb.key
··· if c <> 0 and c <> $DF
····· doc.tx(c)
····· outa[noparse][[/noparse]17] := 1
Thanks for the help,
-Areal
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
· term.start(16)
· kb.start(26, 27)
· repeat
··· if c <> -1
····· term.out(c)
··· c := kb.key
····· doc.tx(c)
-Areal
Along those lines, what are you trying to do with the out[noparse][[/noparse] 17 ] := 1 and the outa[noparse][[/noparse] 16 ] := 1?
and dump it to the screen.
Thats all.
Take out the out[noparse][[/noparse] 16 ] and out[noparse][[/noparse] 17 ] as well as the dira[noparse][[/noparse] 16..23 ] and see what happens.
ok.
It's the DOSonChip that I can't get to do anything.
[noparse]:([/noparse]
Here's my code now. I wired the DOSonChip like this
- UART_TX (pin 3) to P7
- UART_RX (pin 4) to P6
- RESET# (pin 5) to P5
- CTS (pin 13) to VSS
- DoC's VCC to Demo Board's VDD
- DoC's VSS to Demo Board's VSS
OBJ
······· vga··· : "vga_text"
······· kb····· : "keyboard"
······· doc···· : "FullDuplexSerial"
PUB start | i, c
· 'start the vga
· vga.start(16)
· vga.str(string("Press Enter twice to begin.",13))
·'start the keyboard
· kb.start(26, 27)
· repeat
·· if c <> -1
···· vga.out(c)
··· c := kb.key
····· doc.tx(c)·
Has anyone got this to work ??
I can figure anything out if I have the simple first step working
but I don't have the experience to get it going, because I a newbe.
-Areal
Post Edited (Areal Person) : 11/9/2007 1:28:41 AM GMT
While this doesn't help with your problem, I'm simply curious why you chose to use DOSonaCHIP instead
of simply using the Prop directly with the SD routines (ie: PropDOS) With the exception of being able
to make directories, the prop seems to do everything that does.
Not trying to flame, just curious if this is something I should add to my goodies. [noparse]:)[/noparse]
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
You may be very correct. I think I should maybe try that. I have previously bought this
because I hoped it would be simple.
I need simple things to start with, so I can learn, as much is always new to me.
I'm doing well learning, it's just that I seem to always be learning everything all the time...
Thank you, I'll try that as soon as I can.
I think this DOSonChip may not be good, but I really don't know anything about it.
so I really can't say if its good or not.
-Areal
I notice that you're not really resetting the DOSonChip. Make sure you do an OUTA[noparse][[/noparse] 5 ] := 0, then pause for a few milliseconds like with WAITCNT(CLKFREQ/500+CNT), then do an OUTA[noparse][[/noparse] 5 ] := 1.
Another thing is to check the signals from the DOSonChip. Sometimes they label a pin as TX when it's actually meant to be the transmit line from the microprocessor and, similarly, they label a pin as RX when it's actually meant to be the receive line from the microprocessor. I don't have any DOSonChip documentation handy to look at.
I did look at the thread you mentioned and your setup seems to be correct.· Try the reset pulse.
Post Edited (Mike Green) : 11/9/2007 2:09:44 AM GMT
I'll continue to work on it. I followed the directions in the thread, but I don't know whats wrong
I can't get it to do anything with the DOSonChip.
Thank you for your help.
-Areal
