3 wire serial communication BS2p (stepper motor controller)
I'm trying to connect a BS2p40 to one of these:
http://www.eggertelectronics.com/ssc3info.htm
The stepper motor controller has a 3 wire serial connection, RX - TX - G fixed at 9600 Baud, No Parity, 8 Data bits 1 Stop bit.
How do I connect the stamp, and do I have to use Pin 0 and Pin 1 (dedicated serial pins)?
1 - I'm not sure how to connect it, everything I find in the books and online uses 1-wire serial communication.
2 - If I have to use Pin 0 and Pin 1 - is there a way to program and run without moving the cable around? (big pain to program, unplug, run, replug, etc. etc.)
Thanks in advance,
-John
Thanks in advance,
-John
Ultimately I would want to free up 0 and 1 for programming, but I would like to get it working before I complicate anything.· One of my concerns is I notice in the manual that the BS2 may have trouble synchronizing at 9600 due to lack of a hardware input buffer.
Am I ultimately heading for a Max232 or something similar?
-John
-John
