old SCENIX SX28AC wont work with external Resonator
Dear all,
today I got a couple of old SCENIX SX28AC chips. See attached photo .... Insert to the Parallax SX-Tech Board and programmed with SX-B, I found some quriosity about ....
Running with internal 4MHZ RC all works fine. Changing to an external Resonator, nothing works. I tried 4,8,16 and a 20MHZ Reso. and all didn't work.
DEVICE········· SX28,TURBO, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
ID··"HIGH-LOW"
LED··VAR·RB.0
Start:
· DO
··· HIGH LED
··· PAUSE 500
··· LOW LED
··· PAUSE 500
· LOOP
works great as expected, the LED blinks every sec.
DEVICE SX28, TURBO, STACKX, OPTIONX, OSCXT2, BOR26
FREQ 20_000_000
ID··"HIGH-LOW"
LED··VAR·RB.0
Start:
· DO
··· HIGH LED
··· PAUSE 500
··· LOW LED
··· PAUSE 500
· LOOP
wont work, no LED blinks. Indeed, a matching Resonator is connected .... (I also tried OSCXT1 ....)
When I now just change the chip to an UBICOM SX28AC, NOW all works also with the external Resonator ....
My question now is:
Does anybody know ANY differences between the old SCENIX SX28AC and the newer UBICOM SX28AC
If so, is there any way (I guess there must be a way) to let this chip also run with an external Resonator, and if so, what do I have to do within SX/B ????
Thanks to everybody
Gerhard
ID··"HIGH-LOW"
LED··VAR·RB.0
Start:
· DO
··· HIGH LED
··· PAUSE 500
··· LOW LED
··· PAUSE 500
· LOOP
FREQ 20_000_000
ID··"HIGH-LOW"
LED··VAR·RB.0
Start:
· DO
··· HIGH LED
··· PAUSE 500
··· LOW LED
··· PAUSE 500
· LOOP
My question now is:
Thanks to everybody
Gerhard
www.parallax.com/dl/docs/prod/sx/Sx182028DateCode.pdf
Bad spellers of the world untie!
Any help with SX/B would be great ....
Which Fuse-Bit must be set in a different way to run with an external Resonator, and how can this be done in SX/B?
Thanks a lot
Gerhard
I don't think the IDE allows you to change the hex code before you download the code. I think that 's what you need to do, however. I believe the FUSE and FUSEX are the first hex numbers in the "LIST" file. For instance:
The 071B 0F7F are the FUSE and FUSEX config. setup, I believe (one of the forum heavys can elaborate). How you change these with the present IDE so that you can use SX/B is a good question. Old hardware might require SX ver 1.1 in assembly language. I have ver. 1.1 if you need it. I think you might want to make these chips into a silicon art piece and purchase the latest hardware. The SX has come a long way since Parallax took the helm.
The good side is, this chips works pretty well with the internal 4MHZ RC by default. So, at least no need to throw them away ...
Thanks a lot for your help
Gerhard
http://www.parallax.com/Portals/0/Downloads/docs/prod/sx/Sx182028DateCode.pdf
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
