LCD Char. Placement — Parallax Forums
LCD Char. Placement
hmlittle59hmlittle59 Posts: 404
edited 2007-11-07 01:39 in General Discussion
Hello everyone,
On the Serial BackLight(2 x 16) display, is there any way to Place a Char. at any location directly other then (multi. shifts)...
exp.
SEROUT LCDScreen, Baud, [noparse][[/noparse]lcdline1,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt, "OFF"]
ELSE
SEROUT LCDScreen, Baud, [noparse][[/noparse]lcdline1,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt,lcdrt, "ON"]
I guess I could use a For/Next loop with 13 LCDrt...
I have yet to figure out the best way
Any Help Please
hmlittle59
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2007-11-06 06:28
    The REP formatter might do what you want
    Space CON " "
    exp.
    SEROUT LCDScreen, Baud, [noparse][[/noparse]lcdline1,REP Space\10, "OFF"]
    ELSE
    SEROUT LCDScreen, Baud, [noparse][[/noparse]lcdline1,REP Space\10, "ON"]
    Jeff T.
  • stephenwagnerstephenwagner Posts: 147
    edited 2007-11-06 13:12
    From the Parallax Serial LCD Document: 4 X 20 Display
    "There are also direct move commands that you can use to move the cursor to any position on the display
    with a single command. The commands in the range Dec 128 to 143 and Dec 148 to 163 move the
    cursor to the 16 different positions on each of the two lines of the model 27976 and 27977 LCDs. The
    commands in the range Dec 128 to 207 move the cursor to the 20 different positions on each of the four
    lines of the model 27979 LCD."
    http://www.parallax.com/dl/docs/prod/audiovis/SerialLCD-v2.0.pdf
    Line0 con 128
    Line1 con 148
    Line2 con 168
    Line3 con 188
    SEROUT LCDScreen, Baud, [noparse][[/noparse]line0 +9, "BOW"]
    SEROUT LCDScreen, Baud, [noparse][[/noparse]line3 + 8, "STERN"]
    SEROUT LCDScreen, Baud, [noparse][[/noparse]line1 + 9, "PORT"]
    SEROUT LCDScreen, Baud, [noparse][[/noparse]line2 + 12, "STARBORD"]
    I hope this helps.
    SJW
  • hmlittle59hmlittle59 Posts: 404
    thanks stephenwagner,
    I just could not find it, thanks for your help.
    hmlittle59
