resistor needed for GPS?
The GPS receiver says it requires +5V.· I believe this is what the BS2 puts out, no?· Do I need to use a resistor when connecting the I/O to the power?·(From what I've read this is more so for protecting the stamp than the component?)
and if so, what value of resistor?
Or do I just plug and go????
Please advise.
Please advise.
Your statement "connecting the I/O to the power" has me puzzled. The I/O should not be connected to power (Vdd). If you are asking about a 'current limiting resister' between the I/O on the stamp and the GPS unit, then: It's a very good idea to place a 220 ohm resister there. I don't think I did, but do as I say, not as I do. The GPS unit just outputs/receives 5 volt (TTL level) RS232 data.
HTH, Chris
