I am looking for a mini generator
The Lighthouse that uses my solar led array is in need of additional power when the sun is not shining. I came across this site that says the little motors here can produce 1000mA at 12V. All I need is another 40 or so mA. Has anyone here got any experience with the best type of motor to use for this. Are there manufactures that sell tiny generators that might fit this.
I have just started googeling the subject but I know someone here has some experience with this.
http://gizmodo.com/gadgets/gadgets/grad-student-creates-micro-windmill-155875.php
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Is there a battery in your present configuration? If not, a small rechargable battery (or small bank of same) might well get you over the hump. Smaller time periods can often be handled by super-capacitors. Remember, it's not just the amperage you have to worry about, but the time period as well. In other words, I suspect you need additional amp-hours, not just additional amps.
If you opt for a mini-generator as you were proposing, what had you planned to power it - water power, wind power, something else?
Bruce Bates
I tested some of the $2.50 cent steppers from futurlec, (I had bought them from another company for 4x the price a few months back hehe..) those things can give you 100mA at over 12V just spinning back and forth with your fingers. So something like that could work. I suggested he adds a windmill to his lighthouse products. The lighthouses go for $700.00 each for the nicer ones and he has sold many more this year because of my simulated rotating light that has much more light than the menards solar light (single yellow led) that ran from a single 1.2 rechargable battery.
Really I am wondering is specific generators in this size range are made or if just using a stepper is ok to do as well as what seems to be the best type of motor to use, I guess at least 3 phase is better than 1 or 2 and the 5 phase little steppers like i said can generate quite a bit of power.
Personally, I'd stick with the idea of a DC PM motor, primarily due to price and availablity. Additionally, they would be much easier to wire up than a multi-pole stepper motor.
At this juncture my thoughts are running towards a wind turbine sitting atop the "roof" of the lighthouse. I'm speaking of the rounded vane-type wind turbines which are used to exhaust smaller flues, sheds, and other areas, just to create some general air circulation or exhaust.
I'd try running a shaft down from the top onto a gear. The gear, in turn, would engage with a second gear on the motor to provide some mechanical advantage which may be necessary with this system. I just don't know if "miniature" vane turbines are made, and/or if the smallest regular vane turbine would be too large for the lighthouse.
This is the type of thing I was considering:
http://www.grainger.com/Grainger/categories/hvacr/exhaust-fans/wind-driven-turbine-ventilators
Bruce Bates
Wind power is even more unreliable than solar. I think you would be better off with a "charge pump" type solar charge circuit that can charge the batteries even on cloudy days. And more battery capacity. And try to make the light more efficient. Also does anyone REALLY care if the light is not on 1% of the time ?
I also think a "windmill" would detract from the look of the lighthouse, just my personal opinion.
Bean
www.hittconsulting.com
Actually the solar panel I am using with the 4V battery charges very well at low light levels, I have played around with solar charge circuits and with this particular combination it would not be worth the trouble but I will do some more testing on cloudy days. Using 2 panels would help and that is what he is going to do now. I am also going to put in some timer logic to reduce the overnight on time when the battery starts out with a lower charge. Perhaps letting it run for 5 nights in a row when no sun rain days keep it from charging is a little much to expect as well.
http://www.radicalrc.com/shop/?shop=1&cat=182&cart=735597
$25 new
I have one that runs at about 20amps using an E-Flight ESC.
I just tested it but at a few hundred rpm I can only get about 1 volt out of it using 6 schottky diodes. Perhaps you have to be in the thousands oof rpm to get the voltage higher.
Edit: Nevermind; I misread 1000 mA as 10000 mA. Big difference.
Google/Yahoo Scotter Part & Scotterparts.
SJW
So far with a year of use and about 100 lighthouses in the field we have no complaints excecpt for one where the fuse holder was not connected correctly and the battery never charged. I just know the unit is at its limit in on time and brightness with the available solar recharging and I think if it can be done that wind power in combination with the solar would be better than just adding solar capacity and give the customer another product to sell.
or as the beach boys would sing you need a little bit of "excitation"
Post Edited (skylight) : 11/5/2007 7:35:06 PM GMT
