74HC165 Pinout [RESOLVED]
On the 74HC165 (parallel in serial out) datasheet I see pinout labels such as·PL, CE, CP, DS,·Q7, and Q7.· PL, CE, and one of the Q7s· has a line over them.
What do·each of these things stand for?· I understand clock, data, and chipselect, can these be·described in these terms?
Datasheet attached
--DFaust
Post Edited (D Faust) : 11/5/2007 1:06:34 AM GMT
Datasheet attached
--DFaust
pdf
417K
There is a Q7 and /Q7, the bar means that it is the complement (opposite)·of the Q7 output.
So, a bar means "not", opposite, or "active low."
--DFaust
Clock Enable
Device Select
Clock Pulse
There's a table near the beginning of the datasheet that explains the abbreviations.
It's not that I know all this stuff off the top of my head ... I go look at the datasheet.
--DFaust
That's what gets connected to the controller as the data line.
I can't really remember all this stuff in detail, not reliably.
It's so easy to look it up these days with web searches and
the Wikipedia. Anyone with some common sense, basic concepts,
willingness to do some searching and reading, can look like a guru
these days.
If you're going to use the 74HC165 with the BASIC Stamp you can find code and circuits in StampWorks.
--DFaust
--DFaust
--DFaust
