Reading RPM signal from a 3W engine
Hi Guys :
I am trying to use the BS2 to read the RPM signal from a 3W engine. The engine has a hall effect sensor that connects to an ignition control unit
for ignition timing control. The ignition control unit provides a output whicn is the RPM signal (I am not sure what type of signal·is it?). What I want
to do is to use the BS2 with the A/D convertor to read that RPM signal and then do some controller design to control the engine output. I will highly
appreciat that if any of you have experience on it and would like to let me know how I can do it. Thanks !
- Stephen
You need information.
Ignition manual for 3W engines:
www.3w-modellmotoren.com/mounting_tips/manuals_engl/3W_ignition_4_1.pdf
doesn't explain the signal though.
Tachometer accessory:
www.3w-modellmotoren.com/zubehoer/detailseiten/eng_drehzahl.htm
~~ dRu ~~
