Lighthouse?
Im new to Basic Stamps. I recently bought a homework board and have been having fun with it,(led's and such). I recently built a "lighthouse circuit", (ALL info obtained from discoverycircuits,David Johnson) http://www.discovercircuits.com/DJ-Circuits/lighthouseflash5.htm
It slowly ramps up the current to an LED, then flashes it bright, then dims again, like a rotating lighthouse. ,but,
I was wondering if it would be possible to do this same thing on the Homework board? All I really figured out so far on/off and pause durations, and freqouts, to make them flash a bit.
' {$STAMP BS2} ' {$PBASIC 2.5} ' {$PORT COM1} i VAR Word j VAR Byte k VAR Byte main: j=0 k=1 FOR i=1 TO 3000 'fade up slow from dim PULSOUT 15,k j=j+1 IF j=15 THEN j=0 k=k+1 ENDIF NEXT FOR i=k TO 300 'fade up fast PULSOUT 15,i NEXT FOR i=300 TO k 'fade down fast PULSOUT 15,i NEXT j=0 FOR i=3000 TO 1 'fade back to dim slow PULSOUT 15,k j=j+1 IF j=15 THEN j=0 k=k-1 ENDIF NEXT GOTO main▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
