Propeller With EmbeddedBlue Bluetooth
I ordered a Propeller Proto board to experiment with. I would like to use it on a BOE bot in place of the BOE. I wanted to know if anyone has successfully used this board with the EmbeddedBlue Bluetooth device. I did not see any serial-I/O-specific commands in the SPIN language so I'm not sure if this is easily done. Also, I plan to use the DIRRS+ sensor from HVWTech but it also requires serial communications.
I have used the EB500 with the Prop, no problems. I have used both the BS2_functions and FullDuplexSerial to do so. I have not used the demo board, but that should make no differnece.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
