External Crystal problem
I sad. Work my application and... the propeller is stalled. I found the problems after an hour. The 5MHz crystal be wrong. The propeller working without crystal with XTAL1+PLL1X or other PLL settings. [noparse]:)[/noparse]))) Without crystal... I think I will take a measuring. Without crystal the propeller XI-XO working with the environment 50Hz noise. [noparse]:)[/noparse]))
But I have not solutions my problem. Why not working the propeller!
I think the crystal is good (but not tested yet). My brother's propeller XI-XO pins become wrong too about 2 month ago.
The circuit is normal with recommendation, and my and brother's circuit are different.
What is the matter! There are anybody's similar problems?
And what am i doing?
Very thanks!
Gabor
Very thanks!
Gabor
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
thanks.
And I think the cystal is OK too. But the Propeller is go to wrong????
No tuching.. no soldering. Working only...
The trouble seems to stem from driving inductive loads with inadequate grounds such as in breadboard circuits etc. Well that's my impression but others may have their own opinions. Personally though, I've played with a lot of prop chips and haven't had one tiny speck of trouble, but then again the chips are designed into pcbs and not breadboarded.
The other possibility is ESD damage to the sensitive oscillator pins perhaps?
Have you tried running with a crystal configuration but at a lower PLL setting?
CHANT: more info...more info...more info...
*Peter*
I trying some PLL confguration. Not working. Inner RC oscillator is running, and the XTAL1 + PLL2x etc. too. I think the PLL is running, because I try XTAL1+PLL2x and the CPU running (without crystal with environment 50Hz noise) and I calculate about 100Hz Crystal freq. And I control all PLL config and it seems working. It is a funny test [noparse]:)[/noparse])
I think the PIN is breaked inner the chip, or ... nothing else imagine.
Is This a standard problem?
thanks,
Post Edited (HGPL) : 11/1/2007 8:48:09 PM GMT
