Code not working...?
I am writing code for my interactive robot, but for some reason, after I edited something, it suddenly stopped working. All that happens is the emic tts module just resets, and then it doesn't execute the startup sound. What's wrong??
confused Here's the code:
Giggly Googley!
' {$STAMP BS2e}
' {$PBASIC 2.5}
' ***Credits*** --> R2D2 sounds: cpuman3@hotmail.com
cdstime VAR Word ' Photocell RCTIME
pulsecount VAR Word ' pulse counter for servos
counter VAR Word
i VAR Word ' for sound generation
j VAR Word ' for sound generation
frontirstate VAR Byte ' state of front IR
backirstate VAR Byte ' state of rear IR
vol VAR Nib ' current volume
spd VAR Nib ' current speed
ptch VAR Nib ' current pitch
spkr VAR Nib ' for sound generation
frontir CON 10 ' IR port
backir CON 9 ' IR port
' -----[noparse][[/noparse] Emic Commands (Hex Mode) ] --------------------------------------------------------------------------------------
Say CON $00 ' say Engish text
Volume CON $01 ' set volume, 0 - 7
Speed CON $02 ' set speed, 0 - 4
Pitch CON $03 ' set pitch, 0 - 6
AddAbbr CON $04 ' add abbreviation
DelAbbr CON $05 ' delete abbreviation
ListAbbr CON $06 ' list abbreviations
Version CON $07 ' get version
Reset CON $08 ' soft reset
Audio CON $09 ' enable audio in
PhT CON $10 ' start of phonetic text
Help CON $FE ' display help
EOM CON $AA ' end of message
OK CON $55 ' "okay" for hex mode
' -----[noparse][[/noparse] Emic Communication ]---------------------------------------------------------------------------------------------
Baud CON 396 ' 2400 baud, N81
Yes CON 1
No CON 0
Tx PIN 1 ' connects to Emic SIn
Rx PIN 2 ' connects to Emic SOut
Busy PIN 3 ' 1 = busy
Rst PIN 4 ' low to reset Emic TTS
' -----[noparse][[/noparse] Initialization ]-------------------------------------------------------------------------------------------------
spkr = 8 ' AOUT pin (audio out) to the emic
OUTPUT spkr
PAUSE 200
GOSUB Startup_Sound
' -----[noparse][[/noparse] Main Program ]---------------------------------------------------------------------------------------------------
Main:
DO
INPUT frontir
INPUT backir
HIGH 0
PAUSE 100
RCTIME 0, 1, cdstime
DEBUG HOME, "cdstime = ", DEC5 cdstime
frontirstate = IN10
backirstate = IN9
'IF frontirstate = 1 AND backirstate = 0 THEN ' if fron IR detects the floor, and rear IR sees nothing, then
'GOSUB Roam_Around ' roam around
'ENDIF
IF (frontirstate = 1) AND (backirstate = 1) THEN ' if on the ground, and rear IR detects presence, then
counter = counter + 1 ' add 1 to the counter
ENDIF
IF (counter <= 5) AND (counter > 0) THEN ' if it moved by quickly (it's a person not an object), then
counter = 0 ' reset counter to zero
FOR pulsecount = 0 TO 220 ' turn around
PULSOUT 13, 820
PULSOUT 12, 850
NEXT
ENDIF
LOOP
Check_Busy:
PAUSE 1 ' allow busy to activate
DO WHILE (Busy = Yes) : LOOP ' wait until not busy
RETURN
Roam_Around:
Soft_Reset:
GOSUB Check_Busy ' wait for busy to release
SEROUT Tx, Baud, [noparse][[/noparse]Reset, EOM] ' send soft reset
GOSUB Wait_OK
vol = 7 ' set pgm vars to defaults
spd = 2
ptch = 1
RETURN
Hard_Reset: ' reset to default values
LOW Rst ' pull reset line low
PAUSE 0 ' ~100 uS pause
INPUT Rst ' let reset float
GOSUB Wait_OK
vol = 4 ' set pgm vars to defaults
spd = 2
ptch = 1
RETURN
Wait_OK:
SERIN Rx, Baud, 1000, TO_Error, [noparse][[/noparse]WAIT(OK)]
RETURN
TO_Error:
DEBUG CLS, "No response from Emic TTS." ' ruh-roh, Shaggy
END
spd = 2
ptch = 1
RETURN
' -----[noparse][[/noparse] R2D2 Sounds ]----------------------------------------------------------------------------------------------------
sound_0:
FOR j = 1 TO 4
FOR i=2000 TO 50 STEP 400
FREQOUT spkr,10,i
NEXT
FOR i=800 TO 2000 STEP 400
FREQOUT spkr,10,i
NEXT
NEXT
RETURN
sound_1:
FOR i = 800 TO 2000 STEP 100
FREQOUT spkr,10,i
NEXT
FOR i= 2000 TO 50 STEP 100
FREQOUT spkr,10,i
NEXT
RETURN
sound_2:
FOR i = 1000 TO 40 STEP 20
FREQOUT spkr,10,i
NEXT
RETURN
sound_3:
FOR i = 10000 TO 500 STEP 500
FREQOUT spkr,10,i
NEXT
RETURN
sound_4:
FOR i = 10 TO 50 STEP 10
FOR j = 50 TO 10 STEP 10
FREQOUT spkr,15,j*20
NEXT
NEXT
RETURN
sound_5:
FOR i = 1 TO 120 STEP 2
FREQOUT spkr,10,(SIN(i + 40) * 50)
NEXT
RETURN
sound_6:
FREQOUT spkr,10,i * J
NEXT
NEXT
RETURN
sound_7:
FOR i = 30 TO 70 STEP 5
FOR j = 70 TO 30 STEP 5
FREQOUT spkr,10,i*j
NEXT
NEXT
RETURN
sound_8:
FOR i= 30 TO 60 STEP 10
FOR j = 60 TO 30 STEP 10
FREQOUT spkr,10,i * j
NEXT
NEXT
RETURN
sound_9:
FOR i = 1 TO 60 STEP 7
FREQOUT spkr,10,(SIN(i) + 20) * 30
NEXT
RETURN
sound_10:
FOR i = 1 TO 30
FREQOUT spkr,20,(i * 14) + 450
NEXT
RETURN
sound_11:
FREQOUT spkr,20,i
NEXT
RETURN
sound_12:
FOR i = 102 TO 82 STEP 2
FREQOUT spkr,40,(COS(i/100) + 36) * 25
FREQOUT spkr,20,(SIN(i/100) + 20) * 50
NEXT
RETURN
sound_13:
FOR i = 1 TO 10
FREQOUT spkr,40,1195
FREQOUT spkr,40,2571
NEXT
RETURN
sound_14:
FOR i= 1 TO 3
FREQOUT spkr,90, 550
FREQOUT spkr,90, 400
NEXT
RETURN
sound_15:
FOR i = 40 TO 15 STEP 1
FREQOUT spkr,5,I * 90
FREQOUT spkr,5,I * 80
FREQOUT spkr,5,I * 70
FREQOUT spkr,5,I * 60
FREQOUT spkr,5,I * 50
NEXT
RETURN
sound_16:
FOR i = 1 TO 20
FREQOUT spkr,20,1195 - 50 * I
FREQOUT spkr,20,1195 + 50 * I
NEXT
RETURN
sound_17:
FOR i = 0 TO 150 STEP 10
FREQOUT spkr,20,1295 - I
FREQOUT spkr,20,1095 + I
NEXT
RETURN
sound_18:
FOR i = 1 TO 20
FREQOUT spkr,10,I * 50
FREQOUT spkr,10,I * 100
FREQOUT spkr,10,I * 150
NEXT
RETURN
Startup_Sound:
GOSUB Check_Busy
SEROUT Tx, Baud, [noparse][[/noparse]Audio, EOM] ' enable audio input to the emic
FOR i = 1 TO 20
NEXT
FREQOUT spkr,10,i
NEXT
FREQOUT spkr,10,i
NEXT
FOR i = 1 TO 20
NEXT
GOSUB Hard_Reset ' reset the emic so its ready for more commands
GOTO Main ' return to main
Giggly Googley!
It also looks like the "RoamAround" code has been removed.
