Parallax Servo Controller Code question
Hope this question is in the correct forum.
I am using the PSC with a BS2 and have been working with the code to drive multiple servos.· The code I am working with is:
' {$STAMP BS2}
' {$PBASIC 2.5}
'PSC - Controlling four servos - Servos 0 & 2 rotate same direction and
'Servos 1 & 15 rotate same direction.
ch······ VAR···· Byte···················· · 'PSC channel
pw0···· VAR···· Word····················· 'Pulsewidth for Servos 0 & 2
pw1···· VAR···· Word····················· 'Pulsewidth for Servos 1 & 15
ra······ ·VAR···· Byte···················· · 'Ramp rate
Sdat··· CON···· 15························ ·'Serial data pin
baud··· CON···· 396······················· ·'Constant for 2400 baud
· ra· = 7
· ch = 0
DO
· pw0 = 1200
· pw1 =· 300
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch,······ra, pw0.LOWBYTE, pw0.HIGHBYTE, CR]
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch+1,· ·ra, pw1.LOWBYTE, pw1.HIGHBYTE, CR]
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch+2,·· ra, pw0.LOWBYTE, pw0.HIGHBYTE, CR]
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch+15, ra, pw1.LOWBYTE, pw1.HIGHBYTE, CR]
· PAUSE 1000
· pw0 =· 300
· pw1 = 1200
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch,····· ra, pw0.LOWBYTE, pw0.HIGHBYTE, CR]
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch+2,· ·ra, pw0.LOWBYTE, pw0.HIGHBYTE, CR]
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch+15,· ra, pw1.LOWBYTE, pw1.HIGHBYTE, CR]
· PAUSE 1000
LOOP
Is there a way to operate the pulsewidth similar to the channel.· "ch", ch+1, ch+2, ch+15.
Instead of pw0 or pw1 use a statement like:
·pw = 1200
· SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch, ra, pw-900.LOWBYTE, pw-900.HIGHBYTE, CR]
I know the above statement does not work, but is there a way to set the aliases and Modifiers to do so?
EPIC FAILURE -·When everyday run-of-the-mill failure just isn't good enough.
' {$STAMP BS2}
' {$PBASIC 2.5}
· ra· = 7
· ch = 0
DO
· pw0 = 1200
· pw1 =· 300
· PAUSE 1000
· pw0 =· 300
· pw1 = 1200
· PAUSE 1000
LOOP
·pw = 1200
Yes, you can but just slightly differently since you're working with a WORD sized variable and not a BYTE sized variable. Here is what you had that DOESN'T work:
Change it to something like this:
PW_work VAR WORD
PW_work = pw - 900
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch, ra, PW_work.LOWBYTE, PW_work.HIGHBYTE, CR]
There are other ways to do it, but that's about the cleanest, and most understandable.
Bruce Bates
Post Edited (Bruce Bates) : 11/1/2007 3:17:43 AM GMT
Thanks again.
