OK, no laughing, but I have a speaker question...
I hope this doesn't fall under the duh category...· I have a 4 Ohm speaker and don't want to over drive a 1 watt amplifier that requires an 8 ohm speaker. Can I just add a 4 ohm resistor and everything will be alright?
It sure sounds like it should work, but I've been wrong before about things I thougt made sense.
Dan
Dan
Without going into something I almost dont really understand anyway..... Using your 4 ohm speaker on a 1 watt amplifier will not instantly blow the amp as long as you are careful about turning it up. The lower impedance will draw more power not less at the same gain level.
In short, it should play a lot louder than you expect for a while if you really turn it up... Just before it quits playing at all.... [noparse]:D[/noparse]
If the amplifier gain isnt turned up beyond 1 watt output, go for it.
Impedence, I knew I forgot about something.... OK, now I get it, and I do appreciate all of your replies. It is for a Halloween prop, as you probably guessed, and yes...it will be turned up high. After reading your posts, I added a speaker jack, and ran a cord to an amplified pair of computer speakers. Want to play it safe with the sound board.
Thanks again!
Dan
Dan
Make sure you have the polarity of both speakers correct.
Polarity does not impact the load on the amplifier but impact the sound since cones move in opposite directions if polarity
is wrong.
Ed
