Multiplexing Help/Question
I currently multiplex 10 common anode 7 segment displays using a 7447 bcd to seven segment decoder and the basic stamp 40 pin version.
All the displays are on one board and are wired in parallel, All the A segments are wired together, B's, C's, D's, E's, F's, G's. And Connected to one 7447 decoder chip.
I don't use transistors, I only use the stamp pins to turn on and turn off the appropriate display and send the appropriate binary pattern for that display.
The problem:
I want to add 20 more 7 segment displays, Com. Anode, for a total of 30, 7 segment displays, and I only want to use 1 7447 chip to do it. IS THIS Possible? I think it is since only one display is really ever on, our persistence of vision tricks us into thinking they are all lit.
The Second problem:
I need a way to turn on and turn off each segment in sequence without sacrificing all the basic stamp pins to the anodes. AND, I need the displays to be bright enough.
I was thinking of using some kind of external chip, that the stamp can control serially with say 3 pins, and the ten anodes could connect to this external chip. Thus saving me 7 pins instead of ten.
Post Edited (MR) : 10/30/2007 7:46:01 AM GMT
The problem:
The Second problem:
Other considerations:
To get a higher peak current, you have to use lower series resistors on the LED segments. If you leave one display on for any length of time, you'll burn it out, so you'll need to make sure that the 7447 is inhibited on power-on until the Stamp can properly initialize itself (maybe using the blanking input with a pulldown resistor on it).
If the current brightness is adequate, you could use 3 - 7447 drivers, one for each group of 10. You could use 4 - 74HC595 serial output shift registers cascaded in series to drive the anodes using only 3 or 4 I/O pins. The 74HC595 can drive up to 35ma (but a total of only 70ma per device). This way you'd not need the transistors. To save I/O pins on the 7447's, you could even use two more 74HC595's to drive the 7447's.
I will use the 3 7447's and have a row of 10 displays.
THAT excellent it reduces the amount of pins I need to drive the anodes. My only question regarding this. What would the code look like to turn each display on in sequence if they are being driven through the shift registers? Perhaps shiftout pin number, certain number of bits, and a clock pulse, as each bit is shifted it would turn on each display in sequence. Am I correct? Just trying to get an idea.
I am not sure what you mean here.
I know what maximum current rating is on microchips, please explain to me how you figured out 30 displays would be too much current. I don't understand how to figure current in a project, I always have to rely on prototyping, if I can learn to figure the current first it will save me a great deal of time not to mention money because I will know how to figure out total current and determine weather it will exceed the maximum current rating.
The above quote is a good example of what I am asking, how did you figure the current across the ten displays?
Thank You,
MR
The idea of using another pair of 74HC595's is that you'd need at least 4 I/O pins for each of the 3 - 7447's. If you're tight on I/O pins, you could use a pair of 74HC595's cascaded to form a 16 bit register that would be connected to the 3 - 7447's. You'd use a SHIFTOUT statement (as shown in the StampWorks Manual) to transfer the necessary 16 bit value to the 74HC595's, then toggle the load signal to update the output pins on the 74HC595's.
Regarding the "off the cuff" supply current estimates ...
You've currently got 10 displays. Each 7447 output can handle approximately 25mA and I assume that all segments can be driven at the same time since the datasheet doesn't say otherwise and that's how the part would be used. If you drive each display for 10% of the time, that's an average of 2.5mA per display segment per display. The problem is that you're actually providing 25mA per segment and, if you're displaying all 8s, that's 7 x 25 = 175ma. The Stamp pins that are driving the common anodes can't handle this kind of current since they're rated only for maybe 40mA max. and the whole chip is limited to maybe 180mA depending on the chip temperature.
As I go over this, it's obvious that you'll need PNP transistors for the common anodes anyway since the total current can be much more than either the Stamp or the 74HC595's can handle.
Have you considered the MAX7219? I have used this IC in several projects. One chip drives eight 7-segment displays. This IC drives CC displays but I believe there is a version for CA displays. You can see an example of it at the following link. Take care.
http://forums.parallax.com/showthread.php?p=552892
PNP 2n3906
to the common anode displays, the amperage is increased but the display goes to an 8
The display should not go on unless the I/O pin is grounded (made LOW).
If all segments are showing (as 8), then perhaps something funny is going on with the 7447. What signal is being provided to the 7447 when this happens?
Thanks for the help.
For what it's worth, when germanium transistors were the only thing around, they were all PNP. All transistor circuits used PNP transistors and the ground connection was always the positive battery terminal. Vdd was always negative. This was backwards to the way tubes worked and caused all sorts of confusion until people got used to it. Then they invented silicon transistors which initially came in NPN versions only and everything drifted back to the way it was with tubes. Now you've got both and you can think both ways at once.
Thank You for the Clarification, I was wondering why it wasn't working properly. Again, thank you for all your help Mike.
MR
Something isn't working. I have double checked and the wiring to the transistor is just as you said. All the other displays turn off and only one display lights up with a bright 8.
I don't yet have the 74HC595's, they are still in the mail so I used three 74ls194 Universal shift registers, and I have it set serial shift right. I am attaching my code maybe that will help. When ever I just use the stamp pin to turn on and turn off each display it works fine its just the amperage is too low, and I have to pause 1, because any pause rate higher and I will see flicker and not a solid display. now when I use a higher rate say 500 I see each digit cycle on and off in sequence and the amperage is great, but when I change the refresh rate or the pause, the displays get dimmer.
here is my code, I know its the greatest but thats how I learn by making mistakes.
--DFaust
I issue the appropriate binary nibble DIRD=%0001 to the displays which are connected to a 7447 decoder, then I pause the program for a moment to allow the digit to stay lit, then I turn off the digit and proceed to the next digit. The problem, the displays flickers, all thirteen 7 segment displays appear to be solid but the displays look like they bounce. I am trying to figure out the duty cycle needed to eliminate this flicker. Currently I only pause 1. anything higher will cause greater flicker.
So for example if you are using P12-P15 as switching outputs you would declare DIRD = %1111 then in your code you would use OUTD=hour1, OUTD=hour2 etc.
Jeff T.
