HELP how do I do a ip connection via usb2ser in win vista?
Hello,
I use parallax's usb2ser quite often on backing up phone systems for our customers. I used to be able to use it in win xp using a direct cable connection to connect using ip addresses over that connection. I had to get a new laptop which has win vista. I can get putty and dos programs to work almost perfectly(except backspace key). Problem is I don't know how to direct cable connection with vista. BTW parallax's usb2ser is the best I've come across.
Post Edited (Capdiamont) : 11/1/2007 2:52:16 AM GMT
The USB2SER device just provides a TTL level bidirectional serial port without flow control to a USB virtual serial port and helps mimic a "direct cable connection", particularly on computers not equipped with "real" serial ports.
Windows XP changed this by forcing you to use the 'create a new connection' wizard to create a new direct connection via serial, parallel, or irda. In fact, XP's method makes it easier to work with when compared to the old 9x methods of fiddling with the lacking utilities.
Unfortunately, I believe Microsoft has dropped DCC as a method of direct connection. My guess is that there are so many faster/better/cheaper methods of connection (bluetooth, irda, usb, ethernet, wifi, etc).
In your situation, you will likely have to look at third party solutions (Laplink, etc) or move to a modern method. I would recommend ethernet, but this is probably not an option for you as I am betting the phone systems you speak of are ancient.
Harrison
