need help with BOE ASAP!
I am working on a halloween costume so i need this to work asap. The problem is with powering the BOE. I needed a remote switch (long wire and switch) for this project so i went to radioshack and bought a on/off pushbutton switch, i wired it up to some speaker wire and a 9v. I have 2 servos one mini futaba and one standard hitec. The problem is when i turn this thing on, the mini futaba spins and thats it... the code doesn't execute without hitting the reset button which is difficult to get to (reason for remote switch). I put a debug print at the very beginning of the program to print "start"... when i power it on with my switch the servo moves but it never prints out... so its not running the code!!! I put a volt meter on the homemade switch and and noticed the switch has slow response or posible internal arch-ing, because it goes from 9v to 4v to 0v and same when switched on it goes 0v to 4v to 9v. Is the defect in the switch causeing this? its the only one i have and im running out of time... any ideas?
- Stephen
I dont get why its doing this, is it a surge that kills it? would a capacitor fix it?
Post Edited (Johnny-5) : 10/30/2007 1:42:55 AM GMT
btw, its a bs2sx
You really need to post a schematic or at least a careful, ordered description of exactly what you've connected up. Often, the process of doing this will, by itself, show you what's wrong.
Servos will be damaged by using 9V to drive them. The maximum voltage you should use on them is 7.5V, preferably 6 to 7.2V.
Dave
Dave Andreae
Parallax Tech Support·
Also, when the switch is on and the servos are running, what voltage do you read for Vin at the BOE end? I'm wondering if you've got voltage drop issues with the long power cable.
